Our Community is 705,000 Strong. Join Us.
My probe has no spark AT ALL
mademen7622
02-02-2007, 03:32 PM
Someone please help me out,as of now the car is at an auto shop up the street and they cant figure out why it wont get no spark,and theyve been great in past.So i thought id talk directly to some ford probe specialists.We replaced the distributor ,crank sensor,checked grounds fuses,fuel everything and more,but it just turns over fast but wont start and no spark,can anybody tell me something unique that i havent heard?cuz these guys at the auto shop are actually hopeing someone can give thema hint!!!We need ideas.....o ya it is a gt 1996-2.5
GT24V
02-17-2007, 10:31 PM
Once that happened to my car because of a problem with the alarm and I had to uninstall it. Another time it was a connector near the key switch lose. It could also be the coil but the guys from Ford must have changed it already...
Good luck.
tooshort4any
04-11-2007, 12:34 PM
If I read correctly, you said that the engine turns quickly and has no spark. Sounds like the timing belt has given out. It may not have broke, the teeth may have come off of the rubber belt down at the crankshaft/harmonic balancer area. You had not mentioned that this area was checked. Sounds very possible to me.
probiekid23
03-14-2008, 06:03 PM
if ur car has no spark at all try changing the distributer....there about 540$ brand new...i went to a junkie and got one for 135$ that solved all my problems!!
rhandwor
03-15-2008, 08:12 PM
I think the other person who said timing belt is correct as a new distributor was installed. If the belt is good use a 12volt test light put it on the negative coil terminal. When somebody is cranking the engine the light should blink. Also check for power to the primary with the ignition on. Coils can and do go bad but not frequently. A pickup in the distributor pulses the coil.
