Our Community is 662,000 Strong. Join Us.
Power issue ??
mattnbj
01-24-2007, 09:31 AM
Yes ... i have an odd problem i have never encountered ...
ok first my drivers side window stopped working (figured it to be the motor) ... then about a week later the power locks stopped working ... but still works when you put it in drive it locks automatically ... but thats it .. doesn't work any other time ..... when car is runnning and you press the lock button all lights dim ... nothing else ??
jeffcoslacker
01-24-2007, 09:44 AM
I'd pull the button cluster off the driver's door and check the connector and maybe spray some contact cleaner or wd-40 into it and the switches...if it's still working on command from the body control module when you put it in gear, it would seem the problem is in the switches, I'd think...
mattnbj
01-24-2007, 09:56 AM
Ok i tried that to get the window fixed ... but didn't work ... therefore it has to be the motor ... ok and as for the locks its a different place attached to the door handle ... and neither the drivers side or passenger side lock buttons work ...
