check engine light
pygmy warrior
01-19-2007, 08:50 PM
Hey Guys, I am new to the board and I have a question. I have a 2003 Cadillac cts with a check engine light. I took it to Auto Zone and had it scanned and it has two codes. One is a po420 catalyst efficiency below threshold bank 1 and a po430 catalyst efficiency below threshold bank 2. What could be the causes? It did the same thing about 2 weeks ago and the light reset itself. It came back on a few days later with the same codes. btw it has 94,000 miles. Thanks pw
maxwedge
01-22-2007, 03:51 PM
Fairly complex diagnosis, lots of of info on the forums though, do a site search for the p0420.
pygmy warrior
02-04-2007, 10:17 PM
I did!!! 3 posts and one is mine. Not much info.
maxwedge
02-05-2007, 03:32 PM
Cat efficiency is very common, there are a multitude of articles, lengthy, addressing the issue try googling, I could run you by my experiences, if you still cannot find them.
pygmy warrior
02-05-2007, 08:22 PM
Hey Max, I googled and got either p0420 or p0430 but not both together. What could cause both to come on at the same time? Thanks PW
DFBonnett
02-06-2007, 10:40 AM
Go here.....
http://www.obd-codes.com/
Look up both codes then compare causes for commonality.
maxwedge
02-06-2007, 04:42 PM
The best way to check cat efficiency beyond the pcm checking the pre and post sensor inputs, is to get the car good and hot by driving for 1/2 hour, then check the inlet temp at the cat and compare it to the outlet temp, using a non contact thermo, the difference should be at least 100 degrees more at the outlet. Usually both codes are caused by the same issues.
