04 sunfire gaugesalrom04 01-17-2007, 07:54 PM http://cdn5.tribalfusion.com/media/37536.gif (http://a.tribalfusion.com/l.click?clickID=abmyY91UZb9XTZaqRF3ZbTrM1VdnWmbYnQ bfNXTnq3aZba5qU5naMD1r3hUWnQoPbZcns7qpdvK3TZbh5teN 5PfLprrK0sQ0XsYV0cBppTjW5Fv5TF7BUmvVQar5PcZbqQWjN1 HZboTPrn2cBkjYsZcRE&clickURL=http%3a%2f%2fa%2etribalfusion%2ecom) I have a 04 sunfire and my gauges are messed up...don't know how it happen or what is causing it...speedometer says I'm going 80 or higher when I'm stopped and the gauge for the RPM/s says I'm at about 5 or 6...what is causing this and how do I fix it??? HELP!! PLEASE Classicrocjunkie 01-17-2007, 09:01 PM WHen you turn the car off do the needles park where they are suppose to? Possibly issues are a bad wheel speed sensor loacted on the steering knuckels where the gruves from the CV shaft pass under. Its a little black unit with 1 bolt/screw holding it in place.. You need a new VSS sensor- Dealership only part and i will not tell you the location of this one due to the tampering can alter the saftey of the vehicle. Main harness going into the cluster is faulting out. Depending on when you bought you 04 in 2004, you still may be able to swing the gm warrenty on your car. alrom04 01-18-2007, 10:10 AM No the needles don't go back to zero they stay where they are at. Would it still be the same problem?? is this expensive? Thanks for the response, I appreciate the help! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
