Just asking(Duplicolor)
steveboyd1414
01-17-2007, 05:12 AM
Has anyone used Duplicolor directly from a can on a plastic model an then used Duplicolor clear on top of that from the can with any problem?I have tried it and it seams to make a ripple effect as if its eating the plastic.Maybe I should have primed it first.
wouter1981
01-17-2007, 05:33 AM
I haven't used Duplicolur spraycans, but I've used Motip, it's almost the same. It's a good way of spraying you're car bodys, but you defenatly need a suitable primer under it. Duplicolour spraycans are a rather "hot" type of paint.
Always use verry thin coats of paint. The firts 3 layers should be "misted" rather than sprayed.
steveboyd1414
01-17-2007, 07:15 AM
thank you very much.I will try a primer next time
