1993 chevy 3/4 ton van brakespaulyd76 01-16-2007, 04:06 PM my brakes work fine unless i,m trying to stop on ice. they lock up and i hear a noise coming from the passenger side rear it sounds like a louder than normal fuel pump also i hear a slight grinding or rubbing sound only under very low speed braking 10 mph or less also from said side of rear please help i have recently removed brake dust and did a spring job on both sides but problem persists shoes also seem in order however there was a very slight crack in the one shoe on passenger side DFBonnett 01-17-2007, 06:00 PM Is the cracked shoe on the right rear? If it is, then my bet is the shoe is likely the cause. FWIW YMMV vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
