'97 Blazer died while driving
Google
Web AF
cwhitty
01-12-2007, 05:29 PM
My blazer died for the first time ever while I was driving down the road. No hessitation, no bucking, no sputtering, just plain died. All the lights are still illuminated, but the battery light is showing also, "don't know if that means anything or not." The guy that towed me said it was the fuel pump. Although when I tried to start it the fuel pump kicks on fine and never sounds weak after doing it a few times. I would invest in a fuel pressure gauge , but don't want to spend fourty dollars on something I won't use again. Also, I have had a loud ticking noise for a while and was just wandering if this could possibly be the cause too. Thanks, any response would be wonderful!
jonsonton
01-12-2007, 05:42 PM
Do you have good fuel pressure and spark?
Areyou sure the tank is not empty? It could be empty while the guage reads full. Good luck.
cwhitty
01-12-2007, 08:58 PM
Yeah, I put over a half tank of gas in it. Spark not sure about, don't mean to sound dumb but how do you check plugs?
cwhitty
01-12-2007, 09:00 PM
Oh, and by the way it still won't turn over.
DelCoch
01-12-2007, 09:52 PM
. . . I would invest in a fuel pressure gauge , but don't want to spend fourty dollars on something I won't use again. . .
More than likely it could be the fuel pump. So, if it is the pump, will you be replacing it yourself or have a shop do it? If you replace it yourself you'll save enought to buy 4 or 5 fuel pressure gauges. If you're going to have a shop fix it, then just go ahead and take it in.
One needs to know the fuel pressure at the shrader valve before it's possible to rule out a fuel related problem.
Check out this Thread (http://www.automotiveforums.com/vbulletin/showthread.php?t=633098)if you're wondering how difficult it is to replace the fuel pump.
paxfam1
01-12-2007, 10:43 PM
Does your battery have a full charge? If the pump doesnt get proper voltage it cant build enough pressure which would cause the injectors to stay closed. Causing you a no start................I was just thinking on the alternator side...........Just guessin
muddog321
01-13-2007, 07:16 AM
97 has the defective ignition switch - actually the cable and connector- in the column that is the #1 cause of most problems - look at the many posts.
Blue Bowtie
01-13-2007, 08:11 AM
That sounds more like an ignition problem than a fuel problem. The fuel pump has nothing to do with starter operation, but the ignition switch certainly does.
Google
Web AF
