Fly Wheel Loose
Google
Web AF
Mango™
01-12-2007, 09:39 AM
I just put a rebuilt Long Block in my 1991 S-10 4.3L. I have 2400 miles on the new motor and I am hearing a knocking sound. I hear the sound in park and neutral. When I put the car in drive it goes away. I thought a rod went out in the motor. Does any body know how hard to check to see if the fly is loose. I had some one say sounds like the fly wheel is loose.
Is it easy to get to?
Thanks
Chris Stewart
01-13-2007, 09:41 AM
You might check the torque converter bolts first.
If the motor oil is too thick, the lifters will peck.
Mango™
01-22-2007, 10:13 AM
Well I know it is not the rods, I got the ftans mission dust cover and spun the fly wheel by hand and I hear the knowking in either the Torque converter or the trans mission, any suggestions how to check?
Thanks
Mango™
01-22-2007, 04:10 PM
This thread is in the Blazer section, thats why I opened a new one.
Mango™
01-23-2007, 01:00 PM
If the bottom 2 of each side of the transmission bolts are loose and there is a 1/8 to 1/4 inch gap will the transmission or flywheel make a knocking sound. Please do not close this post. The other post is under Blazers, this is a 91 s-10, 4.3 l, v6 new rebuild long block installed.
Thanks
Chris Stewart
01-24-2007, 12:35 AM
I don't know, can you tighten everything up and see if it quit knocking?
Google
Web AF
