blowing fuese 96 jimmy
Google
Web AF
Schums
01-11-2007, 09:04 PM
i just put in a aftermarket radio in my jimmy and now the CTSY(fuse number 2) blows out and when ever i try to put in a new one it blows this fuse controls my inter lights, horn, lifterglass and so on. any help would be nice
email is schums@gamil.com thanks
DelCoch
01-11-2007, 10:32 PM
Does the radio work? If not, it's probably hooked up wrong and that would be the problem. Or, you may have pinched a wire under/inside the dash when you put the radio in, thus you have a shorted out wire. I would pull the radio and look things over.
Schums
01-11-2007, 10:37 PM
radio works fine and looking into it more i think it is a pinched wire either by the radio or on the drivers side by the headlight switch thanks when weather premits im going to dig into it
Schums
03-29-2007, 11:20 PM
i got it fixed after ripping all my panels off i found it it was my rear wiper motor, it was blown out unpluged it and all is good. i do now have a 4x4 issue but im going to keep reading the forums there are enough of those already i should find what i need thanks for the help
DelCoch
03-30-2007, 05:08 PM
Where did you unplug it at? Just wondering if it was a bad unit or a pinched wire?
Schums
03-31-2007, 12:27 AM
i unpluged in from the wiper motor itself in the tailgate the motor is shot since then i have had no problems need to get a new motor still though
Google
Web AF
