Starter wont engage
Google
Web AF
Lifted1988Blazer
01-11-2007, 07:30 PM
Hi everyone im new to this site as of today, I just bought myself a 1988 chevy blazer 4x4 with a 350.I got the truck home last week and 2 days ago i went to start it and it wont crank.When i turn the key to start i here a click but no crank, is my starter bad? i cleaned the battery terminals and also changed the battery, still the same thing, also wondering how many teeth my flywheel would have? 158 or 168? Please help
hanovt
01-11-2007, 09:20 PM
I would first get you battery tested. If it takes a little while to charge and/or it needs to mb replaced, then that's your problem. If not then it's definitly your starter. You can pull it out and get it tested almost anywhere. The clicking means that your selonoid is engaging, so you're getting a lot of energy to the starter, but the starter not turning means it's bad. It's a good idea to just get the battery checked up, but there's probably a 80% chance you need a new starter.
During the cold your starter also needs more amps because resistance goes up in your wires with lower temps; that's why your battery is rated in Cold Cranking Amps.
Hope that helps.
Lifted1988Blazer
01-11-2007, 09:40 PM
I did use 2 different batteries and i did place them on a charger, still got the clicking noise, so thats a sign that my starter is craped out?I was thinking of buying a mini torque starter on ebay brand new, check this out: would this work? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=017&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=270077193711&rd=1,1
I just want to be 100% positive its my starter gone bad before i buy a new 1.Just let me know.
DelCoch
01-11-2007, 10:28 PM
. . I just want to be 100% positive its my starter gone bad before i buy a new 1.Just let me know.
The only way to be 100% positive it's the starter is to pull it and have it tested.
Google
Web AF
