Engine Light on after Oil changetie33 01-11-2007, 04:22 PM just got a oil change and my engine light came on also its make a really loud knocking noise...any ideas..thanks shorod 01-11-2007, 10:02 PM Did you check the oil level to see if they remembered to put oil back in the engine? What year is your Explorer and which engine does it have? If a 1996 or newer, you may be able to borrow an OBD-II scan tool from your local auto parts store and determine why the check engine light is on. If older than 1996, you can check the codes with a jumper wire. Of course if the oil level is low, there's probably not much need to check for codes. If it is low, you may want to contact the place that did the oil change before you fill the oil to the proper level, expecially since you have a loud knock. -Rod butch h 01-11-2007, 10:26 PM Check your oil filter,& oil pan drain plug for looseness/leakage. 97explorersport 01-15-2007, 08:44 AM just got a oil change and my engine light came on also its make a really loud knocking noise...any ideas..thanks OOPS LOOKS LIKE IT NEEDS TO GO BACK TO THE PEOPLE WHO DID IT! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
