I'm f'n starting to hate my logger!!! "no rev" error??
Killa_DSM
01-11-2007, 02:40 AM
So here is my problem. I am trying to run Palm 'n' Stein on my IIIc to do a couple logs. But every time I try to connect I get a error code saying "no rev". Even when I go to look at my engine codes, the same error pop up. I have tried using different cables but still the same outcome. I even tried using my old palm 100m with no luck.
I have also tried using OBD Gauge but that doesnt connect as well.
The interfaces that plugs into the OBD outlet and hotsync cable looks fine. But is there anyway I can test that?
Does anyone have suggestions on how to fix this problem?:banghead:
Thanks
Thanks
Killa_DSM
01-11-2007, 04:39 AM
Well I solved my own problem. I have been working on this for 2 days trying to figure out what was wrong with it. Anyways, for future reference if anyone has the same problem with "no rev" on there Palm'n'Stain try bending the pins in the OBD interface (connects to the ECU plug and hotsync cable) inwards. That solved my problem. I guess it gets kicked around once in a while and the pins get out of shape.
