transmission fluid oil leak
bratt
01-09-2007, 02:47 PM
i changed my transmission pan gasket and filter 3 times
it seems to be leaking fluid from the front of the transmission by the engine oil pan. wierd. i dont get this at all.
the rear seal is not leaking.
it seems to be coming from the front of the tranmission. doesn anyone understand how this could be
troy1
01-09-2007, 09:43 PM
your front seal or pump o-ring could be leaking. You are checking the trans in "N" correct?
wafrederick
01-12-2007, 07:19 AM
It could be the pump bushing too.Replace the torque converter too if it is the pump bushing,you do not want to do it twice and specify if it is a 318 or a 360 for the engine size.The 318 and 360 converters are differant in one way,the 360 has a counterweight on the torque converter
