check engine light
Google
Web AF
97 silverbullet
01-09-2007, 01:27 PM
I have a 94 3/4 ton silverado and the check engine light is on, the cruise doesnt work when it is on but when I turn the truck on and off it works again and the light is gone, anyone here have experience with that or know what the problem is, since its a obd1 i can't run to autozone and check the code and I dont feel like paying for the codes to be read. any info would be appreciated
2000CAYukon
01-09-2007, 01:40 PM
http://www.troublecodes.net/GM
//2000CAYukon
97 silverbullet
01-09-2007, 02:10 PM
well I checked my code and it was a code 12 and the 8th digit is K and I can't find it on the gm code info and my truck is a 94 and the only one I can find is K is an 87-91 with a 2.0L and my truck is 5.7
2000CAYukon
01-09-2007, 03:23 PM
12 is the system is in diagnostics mode. If you use the table at the very end of the page I posted, it will cover most of the codes that your truck can have.
Was the check engine light on before you checked for codes?
//2000CAYukon
silverado122775
01-09-2007, 04:03 PM
//2000CAYukon
His first post states that he had the check engine light on that is why he needed to get the codes.
2000CAYukon
01-09-2007, 04:58 PM
He also said (in his first post) that if he turns it off and back on the light goes out.
//2000CAYukon
97 silverbullet
01-09-2007, 05:41 PM
ok the light came on and then went off I went to go check it but it was off. So the only code that I got was code 12. So do I have to wait till it comes on again and then check it. or what?
2000CAYukon
01-09-2007, 06:12 PM
Yep. On my 90 K1500 Sierra, the light has to be on to pull a code jumpering A and B on the ALDL connector. I also have WinALDL and it will show recent codes so a scan tool should be able to tell you what the code is (or wait until is comes back on).
//2000CAYukon
Google
Web AF
