1998 Lumina wont shift into gear
UsernameX
01-08-2007, 07:33 PM
Hello everyone I made a post earlier but I have had no progress, so I thought I would post an update. My 1998 Lumina LTZ - 3.8 liter, wont shift into gear. My friend as well as jeffcoslacker (from these forums) thought that the soleniod might be the issue. So I took a look at it, I think I am looking at the correct part because there is a bunch of wires comming out of this unit. I tried using some Silicone spray to lube up the part but I still can't shift into gear. =( As I said on my earlier post the gear shifter itself was taken apart and rebuilt from sratch by a mechanic at an eariler date but that didn't solve the issue either.
Thanks for any help,
Branon
jeffcoslacker
01-08-2007, 10:38 PM
Can you hear the solenoid click when you step on the brake?
I think you are looking at the electrical part of the selector harness, the solenoid should only have maybe two wires to it.
UsernameX
02-06-2007, 08:00 PM
Alright, there has been so much snow in Denver lately that it has prevented me from looking at my car, however the snow has cleared. I see the solenoid. When I press in the sensor that the brake is attached to, the gear shifter gets stuck, when I let it go it works again. The whole soleniod system seems to be lose though. I can wiggle the whole box without putting much pressure on it.
I have put pictures on photobucket.com for you guys to check out... hopefully they will help. I don't see anything physcially wrong with the solenoid besides it being lose. Anyways, here they are. Secondly if it is the solenoid, can I pick up one of those at checker auto parts? Or how do I repair it?
http://i155.photobucket.com/albums/s296/usernamex22/BrakeSensor.jpg
http://i155.photobucket.com/albums/s296/usernamex22/Solenoid_2.jpg
http://i155.photobucket.com/albums/s296/usernamex22/Solenoid_1.jpg
Thanks for your help!
soopacee
02-18-2007, 09:28 AM
Branon
i had the same problem with my '97 lumina.....it would go into gear, but the gears didnt match (R was drive and so forth).....i drove it anyway, and then i need a new transmission LOL.....anywho, either the linkage needs to be tightened, or you need a new shifting cable.....i would bet its just the tranny getting ready to go though, as i stated.........also, dont be stubborn like me.....not only did i need a new tranny, but from still driving it after 1st shift went, i also needed a new engine when i blew the head gasket LOL.....the things ppl do just to get to work and feed a family :-)
