Tranny Hesitation
Google
Web AF
VortecWes
01-08-2007, 12:27 PM
My 4L60E (in a '97 C1500, 5.7L...rebuilt 50,000 miles ago) has recently started hesitating going into drive. It goes into reverse with no problems, but when shifting to drive, it takes about 4 seconds to finally get there...sometimes requiring a quick little blip of the throttle.
What's the deal? Shifting solenoid? Something worse?
idmetro
01-11-2007, 04:35 PM
Wes;
Have you done a fluid and filter change since the rebuild? Is the fluid level low? I'd suggest the fluid and filter change which will require dropping the pan allowing inspection for shavings/particles some grey graphite like material on the magnets is normal, larger chunks are not.
VortecWes
01-12-2007, 08:28 AM
No, I haven't done a change...probably should have...but the fluid level is normal. I'll do the change and try that first. Thanks for the advice!
Google
Web AF
