Dome light wont go off
Google
Web AF
coreydon
01-07-2007, 10:39 PM
I keep slamming the door shut and the dome light will not go off i am not sure what else to do at this point. I s there a sensor that can effect that?
mustangmike351c
01-09-2007, 05:33 PM
take the door switch out if this is an older truck
coreydon
01-09-2007, 07:50 PM
its a 2003 f350
unclebubbles
01-09-2007, 11:58 PM
Is your door ajar light on too? I think this is a common problem on the 97 and up trucks. On fords, i think theres a microswitch in the door latch mechanism which is activated when the striker bolt closes the latch. Try spraying it good with wd40 or something similar, open and close it a few times and repeat, see if it helps. Wont hurt anything to try it.
coreydon
01-10-2007, 10:07 PM
yes the light is on i sprayed wd-40 on it today we will see what happens thanks for the info
Google
Web AF
