Screechy Sound On 2001 Malibu Cold Startjoinnaper 01-07-2007, 05:30 PM When I Start From Cold Start, There Is A Piercing Screechy Sound. What Does Anyone Think Is CausIing This Sound? maxwedge 01-08-2007, 10:46 AM Welcome to AF. Possible belt problem or tensioner problem, have someone start the car and look under the hood. joinnaper 01-08-2007, 12:03 PM Welcome to AF. Possible belt problem or tensioner problem, have someone start the car and look under the hood. Thanks very much. I'll give it a try. madmedix 01-10-2007, 10:13 AM Mine does this below freezing only; it's the starter. thankful 03-17-2007, 12:17 PM i have the same problem with my 01 malibu with 55k miles on it. usually happens when it's especially cold and has been sitting for a while. the mechanic at monro couldn't replicate the problem of course, because the car was warm and suggested i leave it overnight so they could start it up and hopefully hear it. which i still haven't done, but since it's warmed up outside i haven't had the problem. the mechanic thought it might be coming from the water pump. Polishpat 03-17-2007, 05:31 PM If its a sudden screaching sound at start-up and then goes away after a few seconds, it may be your belt like someone mentioned before. Check the belt to see if you start seeing cracking on the threaded side. Id recommend picking up a can of White Lithium Grease and spray up a little on the threaded side of the belt......should solve the problem thankful 03-18-2007, 10:55 AM If its a sudden screaching sound at start-up and then goes away after a few seconds, it may be your belt I thought that too, so I had the belts checked out and they were fine in my case. madmedix 04-06-2007, 08:19 PM Problem solved for me: the starter was apparently replaced before I bought the car. It wasn't shimmed. Now it is (with a new starter) and the noise hasn't happened since. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
