02 Tahoe misfire cylinder 1
Google
Web AF
gavinho
01-07-2007, 11:45 AM
Truck is missing and lights the SES. Code for 'misfire in cylinder #1' keeps reoccuring. Have replaced coil on #1, all plugs and all plug wires. Any thoughts?
MT-2500
01-07-2007, 12:23 PM
What engine and mileage?
Does it have good hot blue spark to plug?
Double check spark plug or switch with another one?
Got compression?
Check injector plug in wiring and for injector pulse.
gavinho
01-07-2007, 12:34 PM
5.3L with 44,000 miles. Plug looked good, but have yet to check spark. Carbon build up in throttle body?
MT-2500
01-07-2007, 12:50 PM
Check for good spark and switch plug and or coil /wire with another one and see if miss moves to another cylinder.
gavinho
01-07-2007, 01:25 PM
Good spark, had codes erased, didn't make it out of parking lot before SES came back on. How can a shade tree check injector?
MT-2500
01-07-2007, 06:09 PM
If good spark and plug good and good compression.
First check on a injector would for injector pulse with a injector noid light.
If good injector pulse the best shade tree is to test switch injector with another cylinder and see if miss follows injector.
gavinho
01-07-2007, 06:44 PM
Thanks MT, I'll give it a shot!
MT-2500
01-07-2007, 07:20 PM
Good luck and let us know how it goes.
PS
I have found some where the coil and or injector plug in was not making good connection. Try unplugging and plugging them back on to.
gavinho
01-09-2007, 06:48 AM
#1 injector replaced (by a pro) and problem seems to be fixed at higher revs, but still idles poorly. He thinks poor idle is due to the bottle of injector cleaner clogging fuel filter? Will change the fuel filter. Are we into vacuum leaks? Yikes!
MT-2500
01-09-2007, 09:32 AM
Good luck.
Also check egr valve if a bad idle.
Google
Web AF
