blazer suv starting probs
Google
Web AF
uk_guy
01-07-2007, 05:08 AM
hi new to ur site and buy my name u can guess im in the uk (england for those who dont know ).
any way quick question about the blazer , i have a freind who has one and they are having probs starting it acording to them all the dash lights come on and we have tried to jump start it but nothing
when u turn the key there is no noise at all I.E no clicking or turning over of the engine .
now ive been thinking about wat the prob could b and have coem to the conclusion its either the starter motor or as its an automatic could it b that there is some sort of sensor on the gear box that would poss make the car think its not in park as i have come acrossthis with many british automatics b4 any ideas guys and girls would b much appreciated
cheers from the uk:iceslolan :iceslolan
uk_guy
01-07-2007, 07:05 AM
just realised i have posted this in the wrong part ...........oh well im sure admin will move sorrrrrrrryyyyyyyyy.
also i cant help on wat make of blazer it is but i think its a 97 or 98 model and its def a suv model
cheers:grinno:
Scrapper
01-07-2007, 07:38 AM
i'd say starter..take it off and have it checked at autozone or advanced it's free...good luck.....
SCRAPPER....
DelCoch
01-07-2007, 06:27 PM
If it's a '97, replace the ignition switch. Common problem on '97's in the USA.
BlazerBoyLT98
01-10-2007, 10:24 AM
I would buy a rebuilt starter and not a new one and save yourself the money.
uk_guy
01-24-2007, 01:16 PM
rite guys i know its been a while but found the main prob was their battery was dead as dead so have one coming..............as soon as it arrives hopefully it will work ..if not were do i locate the starter motor as i had a quick look when i was takin the battery off and couldnt c it ...........so im guessing that its located on the under side of the engine ?????cheers
1996LTOwner
02-11-2007, 12:23 AM
I'd check the park switch on the tranny before digging into the starter. Try to start it with the tranny in neutral.
uk_guy
02-11-2007, 01:41 PM
well just to let u guys know after some serious head scratching :banghead: finally got the blazer started.battery as i said b4 was deader than dead so replaced that but it wouldnt start .........she was turning over but not firing so we checked the plugs etc and finally had to really clean up the distributer up as all the pegs were severly corroded and after all the cleaning she started at first turn yippppppeeeeeeeee.
so know my freind has to replace plugs leads and distrbuter and arm but my 1 question now is and it may sound dumb but how the hell do u get to all the plugs:screwy: . we managed to get three out but couldnt get all of them esppecially the ones on the side of the engine that has the steering colum running next to it ..................is there some sort of trick to do or special tool to use ..............plz plz help as im trying help my freind out from having to spend a fortune to get them changed..................also wat is ussually done on a 100 thou mile service .
many thanks for ur help :smokin:
1996LTOwner
02-11-2007, 04:58 PM
I assume you are going through the wheel well? If not, jack the truck, remove the front tires and lift the flap. That will give you a better view. The best way I've found to remove the one next to the steering shaft is to use a "warble" extension to get it good and loose, then you have to use fingers.
DelCoch
02-12-2007, 04:36 AM
Since you're in the UK, does it have the steering wheel on the left side or right side as you sit in the driver's seat?
1996LTOwner
02-12-2007, 05:35 AM
"Since you're in the UK, does it have the steering wheel on the left side or right side as you sit in the driver's seat?"
Ya-know, that never even crossed my mind. It's been a few years but I've even driven in the UK on the right side. I wonder how different the clearance is with the steering shaft on the right side.
Google
Web AF
