Running my power wire for my stero amp
cal06990
01-06-2007, 03:00 PM
How do i run my power cable to my amp? I have tried running it through the firewall and have come across problems. Is there a diagram out there that will help me in this?
stonedraiders1213
01-07-2007, 01:33 AM
the way I ran it is through the fire wall right where the stearing column goes through. underneth the rug and alond side the driver side doors to the trunk. hope this helps out. if you go under neth from the inside you should be able to see some light through the fire wall. let me know if this helps out.
dwalmop
01-08-2007, 12:30 PM
Alternatively, you could get under the dash behind the steering wheel (you'll have to anyway if you're running a cable through) and look and see where nothing is running through the firewall, then verify there is nothing close on the other side, and drill a hole. You'll need a grommet to seal out water, etc., but it's a very clean way to run an amp power cable through your firewall.
Negatoro
01-17-2007, 12:52 AM
...the 'right' way, one hole in firewall, one grommet, one power cable..
What I did...
There's a light grey big a$$ grommet thru the driver's side firewall with a bunch of wires through it. I got a long, thin screwdriver and popped a hole through it from inside the car to the engine bay then fished the cable into the car.
-Mark T.
