Fog lamps on '01 Suburban won't workkjosiahw 01-05-2007, 04:25 PM Hey guys, I've bought a 2001 Suburban about a month ago. Everything's great except I can't get the fog lights to work. I believe I've checked all the fuses and relays, changed the bulbs and it still won't work. The little light below the fog light switch doesn't come on when you push the switch. Any ideas? The only thing I can think of is either a bad switch - which doesn't seem likely, does it? - or maybe whatever tells the fog lights that the hi-beams are on or off isn't working properly. All the connections are good as far as I can trace. Anybody have any thoughts on this? Thanks a ton! mrrose 01-30-2007, 06:51 PM Sounds like your switch is bad, For one it's all plastic,,and theres Little pieces inside the switch, that break all the time, or they just plain ware out. Remove the switch from the vehicle and shake it, bet you hear something, Try a new switch, if thats not it, heck, return it, It's prob. 50.00 new, half that at a salvage yard.But I bet ya anything, it's the switch. kjosiahw 01-31-2007, 12:28 PM I tried a friend's switch that I know works and it didn't help anything, so it's not the switch. I took it in for diagnostics and they said the BCM isn't recieving a signal from the headlight switch that they're on, so the fog lights don't know the headlights are on and they won't work unless the headlights are on. Got any ideas about what might be the problem or maybe how to bypass the BCM? I believe I've checked all the connectors in the line and everything seems good. Bad wire? I don't know. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
