99 Jimmy Noise Heat
Google
Web AF
Wurtis15
01-05-2007, 03:30 PM
GMC Jimmy '99 SLT 6CYL
About 5 months ago my AC went out and I replaced the thermostat (professional diagnosis). I noticed I was low on coolant so I checked the radiator and noticed some rust, so I took it in and got it flushed refilled, etc.
The heat went out again proabably 1 month ago, and a noise started up, which is like a rhythmic squealing (similar to a knock, but just like a screetch). This noise has gotten worse.
(All other fluid levels are fine) My Coolant was completely bone dry (filled 1 month ago) So I filled it up.
I have not noticed any fluid leaks near my car, but it's rained a lot so I'm gonna throw some cardboard under it and see what comes up tonight.
I checked inside for coolant leaks (nothin), I have smelt nothing abnormal, the power level seems okay, it just squeels faster when I hit the gas, so I tend to keep it the speed limit.
I work full time to pay for school and I am super broke 24/7, otherwise I'd take it in.
Any suggestions???
Wurtis15
01-05-2007, 03:34 PM
Oh ya and it seems like I've been goin through gas a lot faster than before.
muddog321
01-05-2007, 05:55 PM
Search posts on lower intake gasket - common and coolant leaks into the engine valley and lifters tap - will destroy the motor if left that way. Shop charges between $500-$700 to fix. Could also be a waterpump leak so look at the 2 holes on the body. Good luck. Squeal could be waterpump, alternator, or idler or tensioner pulleys - if lucky its all the waterpump much cheaper, but odds are intake.
Google
Web AF
