Cav starts then stalls...
Google
Web AF
Kraya
01-05-2007, 07:16 AM
Soo... I go down out to start my car this morning to warm it up before I leave for work and it starts fine, go back in finish getting ready and come back out. The car isnt running. wtf? I start it back up... it runs for about 10 seconds then stalls... start it again, runs for 10 seconds, stalls. So i start it again... give it some gas.... it runs for 5 seconds then stalls. What could POSSIBLY be the problem? Last month i put in new ICM, coil packs, wires and plugs. Im sick and tired of this car and im about to burn it where it sits.
Scrapper
01-05-2007, 07:23 AM
sounds like fuel pump not enough presure..good luck
SCRAPPER.......
Timmy390
01-05-2007, 03:07 PM
Same thing just happen to my daughter.
How low are you on gas? Her gauge showed 1/8 tank but she was bone dry.
Car would start but miss badly and die. I could keep the car running by pumping the gas once it started.
I added 1.5 gallons and the car ran fine. Went to the pumps and put in 13.5 gallons.
BTW, you mention "warming up the car so I'm guessing it's cold there. it was cold when this happen too.
Tim
Kraya
01-05-2007, 03:33 PM
Its not that cold here... when i say warm up, i mean get the windows defrosted and get the motor warmed up.. There is plenty gas in the tank so thats not the problem.... im thinking its one of the injectors or something... who knows... back to the repair shop it goes.
CavLCD128
01-05-2007, 04:30 PM
you said u just installed coil packs, wires, and plugs and all those ignition components....are you sure everythings hooked up correctly? did it start to miss as soon as you installed those things or a few weeks later..?
Kraya
01-05-2007, 05:47 PM
I had all that stuff installed about 2 months ago. The car worked fine... even yesterday, it drove fine... just this morning it started stalling. I have a feeling it is the injector... cause I smell gas... 20 ft away from the car and I smell gas (only when its running)... and one of the injectors is wet with gas. ill try replacing that and see what happens.
PulledOverAgain
01-05-2007, 06:25 PM
Does it stall while you're holding the gas, or will it keep running as long as your foot is on it?
Kraya
01-05-2007, 06:27 PM
It stalls no matter what I do, gas or no gas. It stays on abit longer when I give it gas a bit.
Scrapper
01-06-2007, 07:02 AM
if you relace 1 you should do the others because when you put it back together the others will leak most likly then you'll have to tear it back down..
good luck.
SCRAPPER...
Kraya
01-06-2007, 04:04 PM
Im starting to think... is this car worth it? it has 263,597km on it if its gonna cost me more than $500 to fix, Im not going to bother. Burn it! :)
billyboy128
01-10-2007, 01:44 PM
Have you checked the PCV valve to see that its working and not clogged. You might also want to check the EGR valve to see if its working properly.
Kraya
01-10-2007, 01:46 PM
I havent checked either... ill do that now... just one question.... where is the EGR valve located?
CavLCD128
01-10-2007, 01:47 PM
BURN IT!!!!! hONdA FTW!! :rofl: :nono:
jakegday
01-10-2007, 04:51 PM
pcv valve is on the right side of the valve cover, the egr valve is on the side of the cylinder head
Kraya
01-11-2007, 05:34 PM
I got the car towed to the mechanic to see what he says it is.... I will let you guys know what it is when I find out... and if I burn it... Ill take pictures :)
Kraya
01-12-2007, 05:35 PM
Welp... talked to the mechanic today and he basically said its not worth fixing. The fuel pump is dead and so is one of the injectors, and the gas tank is rotting away so that needs to be replaced also, along with the straps that hold it up. Basically $1400 in parts and labor.... soooo... I called my insurance company today and got it removed from my insurance and called a friend to come tear it apart. See how much I can get for parts from it.
Now that this car is dead, I refuse to buy another cav. In fact, you couldnt pay me to get another one. This F'ing car has cost me over $3500 in repairs in the past 2 years alone... about $5000 since I bought it... an I only paid $4000 for it.
Google
Web AF
