Could Valve Seals Be The Cause Of Misfire And Plugs Fouling
E B
12-31-2006, 10:45 PM
97 Sierra Z-71 Fouling Plugs On Cylinders 4 And 6 Only Using A Quart Of Oil About Every 5 Or 600 Miles I Typically Drive On Highway The Most I Have Changed Cap,plugs And The Wires Look Good.it Has 157,000 Miles On It.
maxwedge
01-01-2007, 10:27 AM
Yes valve seals at their worst can cause this, are the plugs oil fouled? Possible intake gaskets also.
Mr. Smith
01-01-2007, 10:39 AM
FWIW I had to change the intake gaskets on my fathers 96. When I was pulling it apart I noticed it had a spot on the left bank where it was sucking in oil. That explained its oil use after I replaced the stock PCV with the fixed orifice type with little improvement.
Worth a look and if the intake gaskets have never been done I would start there after I ruled out the cylinders with a compression check.
