87 IROC ain't "ROC-in"
never55
12-30-2006, 12:51 AM
1987 IROC - 305 TPI.
Starting difficult.
After starting, quits if throttle isn't applied.
Misses and "backfires" on even light accelleration.
After it reached operating temp, it will not restart after it stalls - until it cools.
New plugs, wires, cap, rotor, ignition module, fuel filter.
No engine codes.
No detectable vacuum leaks.
Ignition timing spot-on.
:banghead:
Help?
Starting difficult.
No engine codes.
:banghead:
Help?
Blue Bowtie
12-30-2006, 06:01 AM
Is there a detectable fuel odor after the engine has been shut off for several minutes?
Can you test fuel pressure while running and after shutdown?
never55
12-30-2006, 06:49 PM
No fuel odor. The Fuel pressures are within specs.
Whoaru99
12-30-2006, 09:11 PM
Did you change all that stuff to try to fix it, or did it start acting up after you changed all the stuff?
never55
01-01-2007, 02:23 PM
As attempts to rectify the problem. I figured it couldn't hurt to eliminate some of the easy stuff.
goldz28
01-01-2007, 02:50 PM
Do you smell rotten eggs? If so the cat could be plugged.
never55
01-01-2007, 07:22 PM
No foul smells. The cat was replaced about 30k ago.
wrightz28
01-02-2007, 09:31 AM
2 classic suspects here:
1-fuel pump
2-ignition control module
1-fuel pump
never55
01-07-2007, 03:27 PM
Both the fuel pump and Ignition module have been replaced - no change.
Blue Bowtie
01-07-2007, 09:55 PM
So pressure is adequate while the pump is running, but what happens to pressure after the engine is shut down? Does pressure remain for at least 20 minutes? I'm thinking that you may have injector or FPR leakage.
You might also want to test for spark during the no-start condition.
