93 Cutlass Supreme - Change ECC to Farenheit
grantbob
12-27-2006, 08:58 AM
I have a 93 Cutlass Supreme with the digital Electronic Climate Control that I recently bought used. The temperature display is in celsius degrees. How do I set it to read farenheit?
Thanks.
Thanks.
grantbob
01-02-2007, 02:12 PM
Does anyone have any ideas of where I might be able to find an answer?
Thanks.
Thanks.
Genopsyde
01-02-2007, 02:43 PM
my 90 had a button on the side of the gauge cluster labeled E/M for english or metric, yours may have the same thing.
grantbob
01-02-2007, 02:53 PM
It does, but it only affects the speedometer unfortuneately. I'm assuming that there is a certain button combination on the climate control that when pushed will change it, but it's not in the manual.
grg
01-31-2007, 12:16 PM
Hi, I have the same problem, but i want to set it to read celcius degrees.
My car is a 94 cutlass supreme.
Thanks.
Thanks.
grantbob
01-31-2007, 02:09 PM
Thanks.
We should trade. :grinyes:
Actually, I read on another forum, that it may be the case of a jumper wire installed on the back of the unit that causes it to read celsius. I haven't attempted to look at mine to see if that is the case. If it is, then you would need to install the jumper on yours. Maybe someone on here knows more about it.
Thanks.
