Programming keyless remote for Lexus LS400
Google
Web AF
Kavanos
09-21-2002, 06:47 PM
Can anyone tell me how to program the keyless remote for a 96 Lexus LS400? I have some instructions, but I can't get it to work. Either the instructions are no good, or the remote is bad.
star5
03-28-2003, 08:21 PM
Thanks for a friend who tested it and it works for his 96 SC300.
Even the remote for this car has the same code as my 97 LS400, this same instruction doesn't work for me, I know it doesn't work for 95 LS400 as well. (failed at step 7)
If somebody had successful experience with 97 LS400, I would like to hear. thanks.
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly
press
lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock
7. With the door open insert your key into the ignition, turn to on
position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If
they
don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second,
release.
The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote.
The locks should cycle. Close the door. Press the lock button on the
remote, the doors should lock. Press again and the doors should
unlock.
kelleher2
10-17-2003, 11:03 PM
i need help with a 2001 Lexus 430. Can anyone help
star5
10-17-2003, 11:34 PM
If it is still under warranty. Go to dealer. Otherwise, wait for answer here or also visit clublexus.com.
Good luck.
Google
Web AF
