Service Engine Light
john m
12-23-2006, 05:51 PM
My Brother-in-law has a 2001 Chevy Lumina which has a Service Engine light on solid whenever he starts the car. He wants to know how to turn it off. He thinks he needs to do a procedure with the ignition switch but doesn't know how.
I have a Dodge RAM 1500 which has a CHECK Engine light that I can clear with my Hand Scanner but I don't know if my scanner will work on his Lumina. Any help as to turning it off will be appreciated. Thanks.
maxwedge
12-23-2006, 05:57 PM
Well I'd get the code and correct it before clearing the code and yes a scanner that will work on the 96 up Dodge will capture codes and clear them on any obd11 car/truck.
john m
12-23-2006, 06:02 PM
Is there any difference between a Service engine and a Check engine light? Alan says that he thinks the Lumina also has a Check light. Thanks. John M.
maxwedge
12-23-2006, 06:10 PM
Same thing the Lumina only has the one check engine lite relative to pcm problems.
