2002 Isuzu Rodeo
Google
Web AF
tjohnikin
12-21-2006, 09:43 PM
I have 2 problems with my vehicle. All of my cd's are stuck in the 6 disc changer and I get an err3 message. Also my check engine light flashes when i accelerate and goes off when I hit the brakes or stop. SOmeone please help!:frown:
amigo-2k
12-21-2006, 11:15 PM
http://isuzufaq.ibctech.ca/#faq48
If you have an autozone nearby take it in to have the codes read. A flashing CEL usually means its a misfire. This is typically caused by a bad intake manifold gasket.
If you are the original owner it is covered for 10yr 120k if you are the second owner it is covered by a 5yr 60k warranty.
player11
12-22-2006, 10:04 AM
the six disc cd player is junk...mine went last year, 02 Rodeo. Costs more to fix than a nice new single disc player.
rodeo02
12-22-2006, 02:57 PM
Home-made CD's tend to jamb up in the rack mechanism. There are online sources that fix factory head-units if that what you want. A *flashing* CEL is a very bad thing for the 3.2 as you will ruin both catalytic converters from fuel overloading if you continue to drive it. That misfire could be caused by a lot of things. #1 cause is from using the wrong spark plugs. LOTS of posts on this.
Joel
Google
Web AF
