Horn??
Google
Web AF
StarLover
12-21-2006, 07:27 PM
I've had my 1996 Chevy Cavalier since April 2006 And Have had numerous problems. But one problem that has become a pain lately is my horn is out. I dont know if its the fuse or the actual horn. I've looked at my fuse box panel label and cant seem to find one that says "Horn" is it labeled undersomething else?? Also If its not the fuse how do I check the actual horn?
Thanks
JStumpalump150
12-21-2006, 08:08 PM
maybe you can look at it and see if there is any damage. it is under the bumper on the left corner if you are looking at the car from the front
StarLover
12-21-2006, 08:12 PM
Alright. I just did that... But I'm not exactly sure what I am looking for... Or how to tell if there is any damage...
NovaRally77
12-21-2006, 08:24 PM
I am not sure what fuse the horn is run through. I know that the control is included in the turn signal/headlight switch assembly. Basically the stick that comes out of the left hand side of the steering wheel. There is a small piece of metal that is spring loaded included in that assembly. When that contacts a piece of metal behind the steering wheel, it activates the horn and makes it sound. If there is something wrong with that assembly, or something making the two not connect, that may be your issue. If you want to test the horn itself, you can simpy run two wires, one from each side of the battery, then connect the positive one to the positive side of the horn and the negative one to the negative side of the horn. I would think that if the horn is in working order, it will sound when the circuit is complete. Good Luck!
DJP2
JStumpalump150
12-21-2006, 11:07 PM
something i notice when i push the horn is that you can hear an electronic click that sounds like it is coming from the glove box, maybe just push the horn a few times and listen for a click and if you hear one that probly means all the electrical stuff is working and the horn it's self is broken. so try that and get back to us
StarLover
12-21-2006, 11:28 PM
No Sound :(
StarLover
12-21-2006, 11:29 PM
But When the horn was working, I dont recall hearing a sound like that...
JStumpalump150
12-22-2006, 01:16 PM
it was probly something you just never noticed cuz i had not noticed until just recently and have had my cavy since march
ford460bigblock
12-22-2006, 02:09 PM
i had the same problem with my 96 that click ur hearing is the relay getting power. what i did was i removed my front head light that way u can see the horn(its that black round shaped thing) with my car the horn just stop working. the problem with my car was bad conncetions at the horn well i fix the wires and the horn works great now
muff34
12-22-2006, 03:11 PM
check the fuse for cig lighter , Mr Haynes says they are together . However my 2000,sunfire has a separate fuse marked horn. 4th slot going across top of fuse panel. it goes in this order,
Ign Mod
blank slot,
rt headlight
Horn
I know it`s not a `96 cavy but they are basically the same cars.
StarLover
12-27-2006, 01:37 AM
Maybe that could be it? I mean a few months back it was dark and I accidently stuck my key in my cig lighter and I saw a huge spark and now the cig lighter doesnt work... maybe that could have something to do with it...
mike2004tct
12-27-2006, 10:22 AM
This is the correct fuse for the '96. If your cigarette lighter works, and you hear a clicking noise when you push the horn (relay clicking as stated above) the problem is your horn. A replacement horn is about $13.00 at most parts stores (I've replaced my daughter's '96 Sunfire horn twice).
To replace it, from underneath the passenger side front bumper, remove the plastic splash guard-about 6 screws, you'll then see the horn.
StarLover
12-28-2006, 12:05 AM
Alright so the fuse for the cig lighter was blown so I replaced it and still nothing :(
JStumpalump150
12-28-2006, 12:18 AM
do you get a clicky sound now when you push the horn? and does your cig lighter work now?
StarLover
12-28-2006, 12:19 AM
No clicky sound and I have no idea about the cig lighter... Unfortunatly when I bought the car the lighter piece didnt come with the car...
muff34
12-28-2006, 03:59 AM
Alright so the fuse for the cig lighter was blown so I replaced it and still nothing :(Did it pop the fuse again ?if it did ,look for the horn where mike 2004tct says it is and follow wires back,probably bare wire there somewhere causing a short and popping fuse
StarLover
12-28-2006, 04:02 AM
Not to sound dumb or anything but Follow Wires back? How and where would I go about doing that? I'm a girl Not too much of a car genius...
muff34
12-28-2006, 04:09 AM
Not to sound dumb or anything but Follow Wires back? How and where would I go about doing that? I'm a girl Not too much of a car genius...ha ha not a genius .some girls are pretty handy around cars.Anyway just find the horn ,there will be wires coming from it .just trace them back as far as you can looking for a bare wire that may touch metal and therefore pop the fuse
StarLover
12-28-2006, 04:12 AM
I wish I were like that... I'm trying to learn more... Cause I'm trying to fix up my car to be "likeable" Anyways... Do you think it would just be easier for me to take it to like rainfords or some mechanical shop like that?
muff34
12-28-2006, 04:20 AM
I wish I were like that... I'm trying to learn more... Cause I'm trying to fix up my car to be "likeable" Anyways... Do you think it would just be easier for me to take it to like rainfords or some mechanical shop like that?Give yourself some credit,you`ve found this site haven`t you? this is not hard to look for just find the horn and look for the wires ,you may surprise yourself .if you start going to shop for every little thing ,they`ll nickel and dime you to death because you do not know.
StarLover
12-28-2006, 04:22 AM
True. And if I find a bare wire, Then what do I do? lol...
muff34
12-28-2006, 04:33 AM
probably the easiest for you if you find the bare wire just get some black electrical tape and tape it up .not the best but it will do for now
StarLover
12-28-2006, 04:35 AM
lol... alright... So am I going to have to lift my car up to see this? My rain gaurd thing is pretty dang low...
StarLover
12-28-2006, 03:45 PM
Yayyyy!! I have a horn now after quite a few bloody knuckles....
I was replacing one of my blinkers this morning and when I went to the auto store to get the bulb I grabbed some blue 15 fuses... Well turns out the fuse I thougth was the cig lighter, Wasnt. So I got home and I replaced it and honked the horn... and It WORKS! Man I feel all cool now cause I've fixed my horn AND light... :-D
muff34
12-29-2006, 03:21 AM
ya gotta like when that happens, the horn and light. Bloody knuckles ,been there and done that ....LOL
highhopesforcars
01-04-2007, 10:02 PM
On my 95 cav the horn didnt work either turns out the cigarett lighter was shorting out and popping the fuse
Dr.Mambo666
01-05-2007, 01:26 AM
Hey star nice work.Don't down ur self every 1 needs to start sumwhere in the meen time keep it up maybe sum day u'll have a 10 sec car ... lol
StarLover
01-05-2007, 01:28 AM
Lol I doubt I'll have a 10 second car... but maybe close to it... haha... But first I have to repair the damages from my accident on the 2nd :/
Dr.Mambo666
01-05-2007, 01:33 AM
wont cost uch to do it ur self just sand it,prime it,color then clear.(with a light sand and washing in between)
StarLover
01-05-2007, 01:34 AM
Yeah... The guy who I helped install my stereo told me he was going to ask his friends dad if he could do it for cheap... cause I'm a perfectionist about how my car looks... so I would never be able to do it
Dr.Mambo666
01-05-2007, 01:37 AM
why i learned by tinkering and doin shit myself.I get greater satisfaction doin things myself anyway....but hey like u said u know sum1 thatil doit so....whatever your choice not my car
StarLover
01-05-2007, 01:38 AM
yeah... I would If I knew what I was doing haha
Dr.Mambo666
01-05-2007, 01:42 AM
ok if u wanna give it a go just look at the non-performance section under painting cars ull see my input....pretty straight forward.All ya got to lose is a few bucks if you mess up n if u do.People invented sand paper for a reason.lol well good luck to ya
Google
Web AF
