back door removalsardutchy 12-21-2006, 05:38 AM hello to all does anyone know how to remove the back doors?...ive been beating on the pins for a week and they arent moveing an inch.....any ideas?...thanks boatbuster 12-21-2006, 05:47 AM dutch doors or barn doors? sardutchy 12-21-2006, 01:22 PM sorry to all they are barn doors...... Blue Bowtie 12-21-2006, 03:05 PM Gotta love that rust and paint. You can remove the plastic trim cap on the outside of the hinge, add some penetrating oil to the two holes, and see if there is a lock pin or set screw inside. ericn1300 12-21-2006, 09:56 PM try using a heat gun to expand the hinge. it might take a couple of heating and cooling cycles to break it loose. CD Smalley 12-22-2006, 07:17 AM twistedtech 12-22-2006, 07:30 PM Me and Billybob here we just done that the otherday.We backed up to a big ole tree in the yurd,got us a chain and we just put it arond the tree and the dour.Gave her sum gas and off she came,lots of room for the boat now. Anyways,I had 2, the pins are a bisch coming out.If you have some time and some torches of some kind,you can build yourself a heat/shield to keep the flame off the body and just warm up the pin to drive it out.If you go with the shield/torch route the best way is to heat the hinge(not the pin) and then INSTANTLY shock it with a bucket of cold water.Quick shot with the hammer amd punch and out it should come. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
