Couple of Cavy questions...zombie_002 12-18-2006, 06:22 PM my 1st question is this i will quote it from another forum. for about 2 - 3 months already (maybe longer) my back up lights have been out. and i have replaced the bulbs numerous times, i have checked and replaced all fuses, i have check the wire connection, i have followed the wires as far as i can and did not see anything cut anywere. could someone help me figure out what is wrong.. i think it could have something to do with the sensor on the shifter not engaging or something im not sure though. i was told to check the switch on the tranny and im not sure exactly were it is i think i might of found it, when i place it in reverse i can see what looks like would be the sensor. it was on the top right side (if your looking dead on at the car) kinda surrounded by the tranny. and to test the switch someone told me to put the car in the on possition and then take a papper clip and stick in the back of the switch and check to see if the back up lights work and if they do then the switch is bad, if they stay off its a hotwire, ground, or bad bulb.. As for my other question.. I have bought a aftermarket tach have it mounted and everything works but i cant seem to find my stock tach wire someone told me it was the white wire number 21 on the computer i have tried every single white wire and nothing has worked but making my car sound like a damn lawnmower ??? so i was wondering if anyone could help me find a tach adaptor of some sort so that it will actually work like its supposed to.. thanks for your help in advance and here is my vehicle i am talking about im sure this will help you figure these things out: 2000 Chevy Cavalier z24, 2.4L, 5 speed manual, Lances133 12-18-2006, 06:25 PM Try, www.clubcav.com you'll get more answers there jakegday 12-19-2006, 08:55 AM heres a couple tach adaptors http://rksport.com/shop/item.asp?itemid=424 http://sunpro.com/product_detail.php?pid=16356 NovaRally77 12-20-2006, 08:56 AM It is your Back-Up Light Sensor. You can get them at Auto Zone for about 20 bucks or you can always check at the junkyard. (FYI: The sensor is the same for the 2.2 and the 2.4) It took me about 5 minutes to change. If you look at the car it is on the right side, on top of the transmission. It is sorta underneath the battery but with a long extension you can get in there very easily. All you have to do is unplug the harness, twist the old one out and put the new one in, and plug it back in. I am going to be headed to work in a few minutes, I will take a picture before I leave and post it when I get there. That way you know what sensor Im talking about. Very easy fix and well worth it! My cavy is the third car I have owned in a row to not have reverse lights, so I finally fixed one of em! DJP2 zombie_002 12-20-2006, 10:10 AM thank you again novarally i went home and tested them and the lights were good they turned on, so i figured out the switch was bad so ill be replacing it soon but here are some pictures i took of it just incase someone is wondering also were it is at for future purposes.. This is one is a picture taken of it from the Top while standing on the driver side of the car. Kinda hard to see but its there..... http://www.teamcyberia.com/pictures/buls1.jpg This Picture is taken from the driver side behind the tire which i have easier to access it from.... http://www.teamcyberia.com/pictures/buls2.jpg and here is one more..... http://www.teamcyberia.com/pictures/buls3.jpg vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
