trans filter and accumulator98gpking 12-15-2006, 12:08 PM ok im in the process of installing a shift kit it says remove the 4 bolts holding on the accumulator..theres nothing in out or around the trans with just 4 bolts. does anybody have a picture of the accumulator it dosent have to be in the car it could be a picture from autozones site or something also how does the trans filter come out does it just pull straight down? BNaylor 12-15-2006, 12:22 PM Pull straight down on the filter. You can rock it slightly side to side to loosen. On the accumulator are 4 mounting bolts located towards the side of the accumulator. The accumulator is the part that has the pipes/lines going to the 2-1 manual servo. 98gpking 12-15-2006, 12:24 PM Pull straight down on the filter. You can rock it slightly side to side to loosen. On the accumulator are 4 mounting bolts located towards the side of the accumulator. The accumulator is the part that has the pipes/lines going to the 2-1 manual servo. ok im gonna go give this a shot. (gulp) i hope all works out ok lol troy1 12-15-2006, 07:21 PM Pull the 8mm blots just leave one in that you can see does not hold it to the case. Just make sure you get the lube tube ( the one with the rubber line )installed all the way in its critical for lube to the geartrain. Don't take the 3 10MM blots out of the servo. Get some green loctite sleeve retainer (640 I think) and put it on the end of the tube and stick it in the hole and let it sit over night. This will help hold that tube in. 98gpking 12-15-2006, 07:37 PM Pull the 8mm blots just leave one in that you can see does not hold it to the case. Just make sure you get the lube tube ( the one with the rubber line )installed all the way in its critical for lube to the geartrain. Don't take the 3 10MM blots out of the servo. Get some green loctite sleeve retainer (640 I think) and put it on the end of the tube and stick it in the hole and let it sit over night. This will help hold that tube in. troy im freaking out dude...i need some help..ive gotten to to point where i dont care if have the shift kit in or not all i want is my car back together...when i pull the accumulator out...should i see springs or should i see the top of the piston. according to the looks of ZZP instructions. it shows i should see springs. but if i see springs when i go to put the accumulator back on the lil thing just spacer slids off the rod...am i suppose to completely remove the accumulator covr or what..im freaking out because i have no help. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
