Engine lacks power, and misfiresmmonte2020 12-13-2006, 08:12 AM 98 Rodeo 3.2L V6 4wd 156K I changed the timing belt because it was getting close. The truck was running fine. Now the engine lacks power and I get misfire at low idle with a P0300. compression is good, new plugs, new crank sensor.:banghead: amigo-2k 12-13-2006, 10:56 AM search here for the procedures (or the FAQ's) on timing belt replacement. sounds like you are a tooth or 2 off. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
