removing super glue
Google
Web AF
98gpking
12-11-2006, 07:10 AM
well....i had my entire car debadged. i didnt have my license for a while so i let my budy borrow my car for a week. he decided i need the emblem on the back saying grand prix so he super glued it on.
he used some kind of contact cement. im afraid if i try and remove the emblem its gonna remove paint too. should i just leave it on or is there an easy way to remove it. i dont think clay will remove this and i wont realy feel like re sanding and buffing my car. i just spent 15 hours doing that.
thanks
richtazz
12-11-2006, 12:24 PM
Find out what he used. If it's super glue, they make a specific super glue remover. Other adhesives are much more aggressive, and you'll be best off leaving the emblem there, and smacking yoru friend in the head.
BNaylor
12-11-2006, 03:09 PM
It will depend on what contact adhesive he used but you can try this procedure. Grand Prix logo on the back? :screwy:
Purpose: To remove a bit of clutter from the back of the car. This is a totally cosmetic mod. Total time: 10 minutes
I first saw this mod on the GTP of Frank Gore and liked the way it made the back of the GTP look cleaner. I had also heard of various methods of removing the badges. The most popular seemed to be heating the plastic badge until it came off with relatively little effort using a commercial heat gun. The result was a clean removal but often left the badges warped or bent out of shape.
I used a combination of the floss and hairdryer technique. Basically what I did was pass a doubled up line of floss between the car paint and the badge being careful to pull away from the paint and cause no damage anywhere. This then left the sticky rubber residue of about 1/16th to 1/8th of an inch thick on the car. This is where the hairdryer came in. I heated the left-over rubber residue to the point that it was uncomfortable to touch and rubbed it off into a small ball using my bare fingers. I then reheated the area and dabbed the residue rolled up into a small sticky ball onto the area to further remove as much of it as possible. At this point there was very little left but it was not perfect. I sauntered into my garage grabbed a piece of soft paper towel and sprayed a bit of WD-40 onto it. By gently rubbing the WD-40 soaked paper towel it safely removed 100 of whatever residue was left. I then thoroughly washed the area with a gentle soap and water I just happened to be Dawning my car in preparation for its 2nd claying and waxing party until it was impossible to see where the original badging was.
The end result is a pleasantly bare area just below the trunk keyhole. In the future I might put something else there but for the moment I quite enjoy it as it is.
By Jerry.
Google
Web AF
