I smell gas in the cab of my 98 trooperAmysTrooper 12-07-2006, 02:06 AM Ok I have checked this vehicle over well and do not see gas pooling anywhere , no leaks on the floor but it smells of gas (not exhaust) when I turn on my heater/defrost unit. ALSO the garage in which its parked smells of gas but again I cant find any leaks or pooling. WHAT CAN IT BE??? Thanks guys. atfdmike 12-07-2006, 11:48 AM Have you looked on the top of the engine and fuel rails to see if there is any pooling in injector sites or on top of valley? I found no technical service bulletins for your vehicle for a gasoline smell. There is a bulletin for an A/C odor and a sulphur odor from the exhaust. Just in case, here is one of them. 1998 Isuzu Truck Trooper LTD V6-3.5L Vehicle Level (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741) http://library.alldatapro.com/images/a_003366.gif Technical Service Bulletins (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34850750) http://library.alldatapro.com/images/a_003366.gif All Technical Service Bulletins (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34850750/42063452) http://library.alldatapro.com/images/arrow1.gif HVAC System - Unpleasant Odors When In Use (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34850750/42063452/120930309) http://library.alldatapro.com/images/arrow2.gifhttp://library.alldatapro.com/images/blnk_spc.gifHVAC System - Unpleasant Odors When In UseBULLETIN NUMBER: SB99-12-S002 ISSUE DATE: MARCH 1999 GROUP: AIR CONDITIONING AFFECTED VEHICLES All Isuzu light vehicles equipped with air conditioning. SERVICE INFORMATION Condition: Some Isuzu owners may experience unpleasant odors when using the ventilation system. These odors may be more pronounced after engaging the HVAC system, especially within 12 to 24 hours after previous use. Possible Cause: The above condition is typically caused by residual c6ndensation in the evaporator case (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34865608/56272124) after A/C use. The odor can be aggravated by particulates such as: cigarette/cigar smoke, airborne molds, pollen, algae and bacteria trapped in the HVAC system and continually recirculated. http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34850750/42063452/120930309/79014647/79014648 Correction: To minimize or eliminate unpleasant odors originating from the HVAC system, use available tool # J43681-A (Figure 1) to perform the procedure outlined in this bulletin. SERVICE PROCEDURE 1.Set the temperature selector to the warmest setting and select A/C off. 2.Dry the A/C evaporator by running hot air over the core with the mode control knob on recirculation mode for approximately five (5) minutes. * On some models (without the manual A/C ON/OFF button), select "MAX A/C" mode with A/C fuse removed to disable the A/C compressor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34865608/34865609). 3.Remove the glove box while drying the A/C evaporator. http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34850750/42063452/120930309/79014647/79014649 4.Drill 5/16"(8 mm) hole in the upper-right corner of the evaporator case (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34865608/56272124). (Figure 2) CAUTION Be certain to set the drill bit depth at no more than 1/4" (6 mm). Mark the drill bit 1/4"(6 mm) or less from its tip as a guide. Extending the drill bit deeper into the case after the hole has been drilled will risk puncturing the evaporator core (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34865608/56272263). 5.With the blower fan on medium to high speed and using the outside air setting, dispense the deodorizer material J43681-A (w/applicator nozzle) with the following: ^Place the tip of the nozzle into the 5/16"(8 mm) drilled hole of A/C evaporator core casing. (Figure 3) ^Using no more than 30 PSI shop air, set nozzle fluid flow adjustment to full open position (full counterclockwise position), and flood the A/C evaporator core by discharging 4 fluid ounces of treatment chemical into the casing. NOTE 2 fluid ounces are required to prime the application tubing and nozzle. The 1/2 gallon container label is graduated in 4 ounce increments. 6.Plug the 5/16" (8 mm) hole with a 5/16" (8 mm) plug supplied with each treatment kit. 7.Run the ventilation system 5-10 minutes with the fan on high and windows open. 8.Reinstall the glove box and any panels, previously removed during Step 2. * Reinstall the A/C fuse, if previously removed. The application should last 3-4 months under normal use. Repeat the above service procedure, should odors return after such time. NOTE As a preventive measure, service personnel may also suggest to the customer to run the fan blower at mid to high speed with the A/C off and using the outside air setting to dry the evaporator for the last few minutes before turning off the vehicle. PARTS INFORMATION KENT-MOORE Part Number Description QuantityJ43681-A HVAC SYSTEM 1 Kit* Cleaner-Freshner-Protectant with application nozzleJ43681-5 Replacement Chemical (Refill) (2-1/2 gallon containers) *A sufficient quantity of 5/16"(6 mm) plug is included with each treatment kit. NOTE:This product will be available for purchase beginning mid-April 1999. GREEN ISLAND INC. WARRANTY INFORMATION Please refer to the warranty information included with each HVAC system treatment kit. Green Island Inc. warrants to the buyers that the products are free from defects with a 1 year Limited Warranty. For inquiries regarding warranty claim information for Green Island Inc. products contact their customer support at 1-800.718-1131. ISUZU WARRANTY CLAIM INFORMATION Isuzu warranty does not cover this service.:nono: AmysTrooper 12-07-2006, 02:10 PM Thank you for the email and info. I crawled on top of this motor while running and seen nothing at all. I was under the truck too and nothing. I did read an article on an Nissan pathfinder that had this same problem. That truck and an emissions canister under the hood that was the cause in a way. Actually the gas tank vented thru the canister and two, 1 way valves. The vales which could become stuck was the problem and the canister help the gas vapor and when the defrost was on it would smell of gas and also smell the garage it was parked in to, just as ours is doing. Do you know if there is such a system as this on my trooper?? I was thinking that with the weather change (last week to very cold) here in michigan that possibly a 1 way valve has become stuck,froze or whatever and thats why the smell. What do you think?? Thanks again. atfdmike 12-07-2006, 02:31 PM Hi again, this forum is great because you can post a lot of information and diagrams. You do have a purge canister, info below. That is a good idea to check along with the lines to and from. I would check the engine and fuel rail for leakage AFTER shutting off the engine. A warm engine and high pressure gas and revolving pulleys and belts is a recipe for disaster, so be careful. Good luck and hope this helps.. 1998 Isuzu Truck Trooper LTD V6-3.5L Vehicle Level (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741) http://library.alldatapro.com/images/a_003366.gif Powertrain Management (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029) http://library.alldatapro.com/images/a_003366.gif Emission Control Systems (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699) http://library.alldatapro.com/images/a_003366.gif Evaporative Emission Control Canister (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) http://library.alldatapro.com/images/arrow1.gif Testing and Inspection (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077/34858069) http://library.alldatapro.com/images/arrow2.gifhttp://library.alldatapro.com/images/blnk_spc.gifTesting and Inspection If the canister is cracked or damaged, replace the canister. If fuel is leaking from the canister, replace the canister and check hoses and hose routing. Advise operator not to over-fill fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372). 1998 Isuzu Truck Trooper LTD V6-3.5L Vehicle Level (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741) http://library.alldatapro.com/images/a_003366.gif Powertrain Management (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029) http://library.alldatapro.com/images/a_003366.gif Emission Control Systems (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699) http://library.alldatapro.com/images/a_003366.gif Evaporative Emissions System (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969) http://library.alldatapro.com/images/a_003366.gif Description and Operation (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183) http://library.alldatapro.com/images/arrow1.gif EVAP Emission Control System Operation (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277041) http://library.alldatapro.com/images/arrow2.gifhttp://library.alldatapro.com/images/blnk_spc.gifEVAP Emission Control System OperationThe EVAP canister purge is controlled by a solenoid valve that allows the manifold vacuum to purge the canister. The powertrain control module (PCM) supplies a ground to energize the solenoid valve (purge on). The EVAP purge solenoid control is pulse-width modulated (PWM) (turned on and off several times a second). The duty cycle (pulse width) is determined by engine operating conditions including load, throttle positron, coolant temperature and ambient temperature. The duty cycle is calculated by the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125). The output is commanded when the appropriate conditions have been met. These conditions are: The engine is fully warmed up. The engine has been running for a specified time. The IAT reading is above 10°C (50°F). A continuous purge condition with no purge commanded by the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) will set a DTC P1441.Poor idle, stalling and poor driveability can be caused by: A malfunctioning purge solenoid. A damaged canister. Hoses that are split, cracked, or not connected properly.1998 Isuzu Truck Trooper LTD V6-3.5L Vehicle Level (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741) http://library.alldatapro.com/images/a_003366.gif Powertrain Management (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029) http://library.alldatapro.com/images/a_003366.gif Emission Control Systems (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699) http://library.alldatapro.com/images/a_003366.gif Evaporative Emissions System (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969) http://library.alldatapro.com/images/a_003366.gif Description and Operation (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183) http://library.alldatapro.com/images/arrow1.gif Enhanced Evaporative Emission Control System (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044) http://library.alldatapro.com/images/arrow2.gifhttp://library.alldatapro.com/images/blnk_spc.gifEnhanced Evaporative Emission Control System http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P4R0H~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044/78526273/78526274 The basic purpose of the Enhanced Evaporative Emissions control system is the same as other EVAP systems. A charcoal-filled canister captures and stores gasoline fumes. When the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) determines that the time is right, it opens a purge valve which allows engine vacuum to draw the fumes into the intake manifold. The difference between this and other systems is that the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) monitors the vacuum and/or pressure in the system to determine if there is any leakage. If the PCM determines that the EVAP system is leaking or not functioning properly, it sets a Diagnostic Trouble Code (DTC) in the PCM memory. The enhanced EVAP system is required to detect evaporative fuel system leaks as small as 0.040 in. (1.0 mm) between the fuel filler cap (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/56206883) and purge solenoid. The system can test the evaporative system integrity by applying a vacuum signal (ported or manifold) to the fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372) to create a small vacuum. The PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) then monitors the ability of the system to maintain the vacuum. If the vacuum remains for a specified period of time, there are no evaporative leaks and a PASS report is sent to the diagnostic executive. If there is a leak, the system either will not achieve a vacuum, or a vacuum cannot be maintained. Usually, a failure can only be detected afier a cold start with a trip of sufficient length and driving conditions to run the needed tests. The enhanced EVAP system diagnostic will conduct up to eight specific sub-tests to detect fault conditions. If the diagnostic fails a sub-test, the PCM will store a Diagnostic Trouble Code (DTC) to indicate the type of detected. http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044/78526273/78526275 http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044/78526273/78526276 http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044/78526273/78526277 Electrical Components The electrical components that make up the enhanced EVAP system are: Fuel Tank Pressure Sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367736). The fuel tank pressure sensor is a three-wire strain gauge sensor similar to a common MAP sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/34857526). However, the fuel tank pressure sensor has very different electrical characteristics due to its pressure differential design. The sensor measures the difference between the air pressure (or vacuum) in the fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372) and the outside air pressure. The sensor mounts at the top of the fuel pump assembly. A three-wire electrical harness connects it to the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125). The PCM supplies a five-volt reference voltage and a ground to the sensor. The sensor will return a voltage between 0.1 and 4.9 volts. When the air pressure in the fuel tank is equal to the outside air pressure, such as when the fuel cap is removed, the output voltage of the sensor will be 1.3 to 1.7 volts. When the air pressure in the fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372) is 4.5 in. H2O (1 .25 kPa),the sensor output voltage will be 0.5±0.2 V. When there is neither vacuum nor pressure in the fuel tank, the sensor voltage will be 1.5 V. At -14 in. H2O (-3.75 kPa), the sensor voltage will be 4.5±0.2 V. EVAP Canister Purge Solenoid. Normally closed, the purge solenoid opens upon the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125)'s signal to allow engine vacuum to purge gasoline fumes from the canister. Mounted on the water pipe to front of the engine assembly. EVAP Canister Vent Solenoid. Located next to the canister, the vent solenoid opens to allow air into the EVAP system. Fresh air is necessary to completely remove gasoline fumes from the canister during purge. The EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent solenoid closes to seal off the evaporative emissions system for leak testing. Fuel Level Sensor. The fuel level sensor is an important input to the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) for the enhanced EVAP system diagnostic. The PCM needs fuel level information to know the volume of fuel in the tank. The fuel level affects the rate of change of air pressure in the EVAP system. Several of the enhanced EVAP system diagnostic sub-tests are dependent upon correct fuel level information. The diagnostic will not run when the tank is less than 15% or more than 85% full. Be sure to diagnose any Fuel Level Sensor DTCs first, as they can cause other DTCs to set. Manifold Absolute Pressure (MAP) Sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/34857526). The PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) compares the signals from the fuel tank pressure sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367736) and the MAP sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/34857526) to ensure that a relative vacuum is maintained the EVAP system.http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044/78526273/78526278 http://library.alldatapro.com/alldata/LIB~C32056~R0~OB0~P3R0H~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34857969/34850183/73277044/78526273/78526279 Non-Electrical Components Purge/Vacuum Hoses. Made of rubber compounds, these hoses route the gasoline fumes from their sources to the canister and from the canister to the intake air flow. EVAP Canister. Mounted on a bracket ahead of the fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372), the canister stores fuel vapors until the PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) determines that engine conditions are right for them to be remove and burned. Fuel Tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372). The tank has a built-in air space designed for the collection of gasoline fumes. Vacuum Source. The vacuum source is split between two ports, one on either side of the throttle body (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859505). Fuel Cap. The fuel cap is designed to be an integral part of the EVAP system.System Fault Detection The EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) leak detection strategy is based on applying vacuum to the EVAP system and monitoring vacuum decay. The PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) monitors vacuum level via the fuel tank pressure sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367736). At an appropriate time, the EVAP purge solenoid and the EVAP vent solenoid are turned "ON", allowing the engine vacuum to draw a small vacuum on the entire evaporative emission system. After the desired vacuum level has been achieved, the EVAP purge solenoid is turned "OFF", sealing the system. A leak is detected by monitoring for a decrease in vacuum level over a given time period, all other variables remaining constant. A small leak in the system will cause DTC P0442 to be set. If the desired vacuum level cannot be achieved in the test described above, a large leak or a faulty EVAP purge solenoid is indicated. Leaks can be caused by the following conditions: Disconnected or faulty fuel tank pressure sensor (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367736) Missing or faulty fuel cap Disconnected, damaged, pinched, or blocked EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) purge line Disconnected or damaged EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent hose Disconnected, damaged, pinched, or blocked fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372) vapor line Disconnected or faulty EVAP purge solenoid Disconnected or faulty EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent solenoid Open ignition feed circuit to the EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent or purge solenoid Damaged EVAP canister Leaking fuel sender assembly O-ring Leaking fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372) or fuel filler neck A restricted or blocked EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent path is detected by drawing vacuum into the EVAP system, turning "OFF" the EVAP vent solenoid and the EVAP purge solenoid (EVAP vent solenoid "OPEN," EVAP purge Pulse Width Modulate (PWM) "0%") and monitoring the fuel tank vacuum sensor input. With the EVAP vent solenoid open, any vacuum in the system should decrease quickly unless the vent path is blocked. A blockage like this will set DTC P0446 and can be caused by the following conditions: Faulty EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent solenoid (stuck closed) Plugged, kinked or pinched vent hose Shorted EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent solenoid driver circuit Plugged EVAP canister The PCM (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857030/101367125) supplies a ground to energize the purge solenoid (purge "ON"). The EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) purge control is PWM, or turned "ON" and "OFF", several times a second. The duty cycle (pulse width) is determined by engine operating conditions including load, throttle position, coolant temperature and ambient temperature. The duty cycle is calculated by the PCM and the output is commanded when the appropriate conditions have been met.The system checks for conditions that cause the EVAP system to purge continuously by commanding the EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) vent solenoid ~ON" and the EVAP purge solenoid "OFF" (EVAP vent solenoid "CLOSED," EVAP purge PWM "0%"). If fuel tank (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34858641/34859372) vacuum level increases during the test, a continuous purge flow condition is indicated, which will set a DTC P1441. This can be cause by the following conditions: EVAP purge solenoid leaking EVAP (http://library.alldatapro.com/alldata/LIB~C32056~R0~OD~N/0/56775861/62685414/62685439/62685440/34853741/34857029/34857699/34872077) purge and engine vacuum lines switched at the EVAP purge solenoid EVAP purge solenoid driver circuit grounded AmysTrooper 12-08-2006, 04:55 PM Thanks again for the great info that will sure help. I have another thing to add to this mystery. Today I went to check the truck in the morning where its inside the garage. The last week or so it has smelled the garage up with gas fumes too as I said before. Today NOTHING not even a trace of gas. I asked my wife how much gas she had in the truck and she said it needed to be filled because it was near empty. So I told her to fill it up only to half way and I will check it tomorrow morning. Weired huh?? nujac 12-19-2006, 06:28 AM I just had to deal with what seems to be your same problem. I took a trip to Houston last month and noticed that I could smell gas in the cab. Houston has lots of refineries so I just thought I was smelling Houston TX. Nothing happen for two weeks then I started smelling gas again from time to time but could not fine gas anywhere. A week or two later the problem got worst. It turned out to be the fuel hose that runs between the passenager side intake manifold and the timing belt cover on the top of the engine developed a leak form age and heat. There are two 8" fuel hoses there, one on top the other. I replaced both. Be sure to use high pressure fuel line and also replace the hose clamps if they seem weak. AmysTrooper 12-19-2006, 11:20 PM I will try anything at this point. Its been on / off for a few weeks now. Last few days no matter if tank is full or near empty, NOTHING!!! Frustrating to say the least. I put it on the hoist and looked for an hour and nothing. It has become warmer in michigan the last week so Im wondering if that has something to do with it. CrAzY MaN...:screwy: AmysTrooper 01-09-2007, 06:31 AM If anyone has been following this issue here is what is going on. NOTHING!!! The problem has cured itself and we havent smelled gas since my last post. With the warm weather it is gone, but we have a cold snap comming next week. We will see what happens then. SPRaYeD9 01-28-2007, 03:23 AM just ignore it vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
