94 Rodeo squeels when accelerator mashed
Google
Web AF
trates
12-03-2006, 07:59 PM
I got our mechanic to change the three belts in the front (AC, fan belt and ??) and it still squeels. What could the problem be??
marcusinaus
12-03-2006, 08:30 PM
i have had same drama it is the condenser oil if you have a mate in ac repair can dodge it up with thicker oil otherwise time for new condenser you may have found this out already take care mate go rodeo i got 93 space cab big stereo fresh paint need turbo options now ac still squeels somtimes lol my:2cents:
trates
12-03-2006, 09:09 PM
Thanks Mate!
I think that is what my mechanic was trying to tell me, but he was not sure!
trooperbc
12-03-2006, 09:26 PM
before you go the ac route, just make sure that your mechanic has adjusted your belts *tight* enough. in my experience, the correct tightness is more than i'm used to, and i generally have to retighten them (mostly the alternator belt) until the squeel goes away
//bc
p.s. """the three belts in the front (AC, fan belt and ??) """ and power steering pump belt.
marcusinaus
12-04-2006, 12:34 AM
//bc
true! i just assumed the mecenic would have done them tight thanks for that i will check mine to i have 2.6 peterol four cyl same ac though that is why i had same trouble toped oil up in compresser and all was good i am having trouble with oil pressure cant find leak any ideas loosing oil with no smoke to really got me stumpped pressure getting worse around 4kg per cm2 when idile any sites were they help with this new to web and computers:popcorn:
Cat Fuzz
12-04-2006, 12:40 AM
Alternator belt does need to be a bit tighter than what's considered normal to prevent squeals.
Google
Web AF
