2ohm or 4ohm sub...
Google
Web AF
jtvyper456
12-01-2006, 06:01 PM
Wandering which sub I should get...a Kicker CVR with a 2ohm or a Kicker CVR with a 4ohm...whats the difference? Which is better etc.? I ordered the 2ohm without realizing it...guess that's what I get, but I can call them and change it if need be.
hotrod_chevyz
12-01-2006, 06:26 PM
It really depends on if your amp is 2 ohm stable.
here is how my kicker zr600 plays out.
150watts RMS x 2 @ 4ohm Stereo
300watts RMS x 2 @ 2ohm Stereo
275watts RMS x 2 @ 1ohm Stereo
600watts RMS x 1 @ 4ohm Bridged Mono
550watts RMS x 1 @ 2ohm Bridged Mono
Typical: 750w RMS x 1 @ 4ohm Bridged
stone_mound_camaro
12-01-2006, 06:30 PM
it all depends on which amp you have matching them...cuz.. if you have an amp way more powerful than what the subs can handle, you might not want the ohm load low.....you did good tho, cuz you only have one sub... you can wire the dual 2 ohm voice coils and get a 1 ohm load and get the most out of your amp. (assuming that our amp is stable at one ohm.) if its not stable at 1 ohm, i would suggest giving it back and taking the 4ohm dual voice coil sub.
but yea....the diffference between 2 ohm subs and 4 ohm subs is jus the configurations of wiring options that you have..... if you have multiple subs and such...with 2 ohm, the lowest you can go is 1 ohm, with a SINGLE sub. with 4 ohm, the lowest is 2ohms for a SINGLE sub. I prefer dual 4 ohm subs tho, cuz i always buy subs in pairs so that i can get a 1 ohm load to my amp when i combine them. if you have a pair of two ohm subs, the lowest you get is .5 Ohms....and most amps arent stable with that small of an ohm load.
this is wiring parallel..
1 DVC 4 ohm woofer parallel= 2 ohms
1 DVC 2ohm woofer parallel= 1 ohm
2- DVC 4ohm woofers- parallel=1 ohm
2- DVC 2 ohm woffers-parallel=.5 ohms
this is the load you get series/parallel
1 DVC 4ohm woofer- series= 8 ohm
1 DVC 2 ohm woofer- seires= 4 ohms
2-DVC 4 ohm woofers series= 4 ohms
2 DVC 2 ohm woofers seires= 2 ohm
hope that made sense, im kinda in a hurry now, i'll clean it up a lil bit later
jtvyper456
12-01-2006, 11:17 PM
Actually, I got two of them :p, buy one get one free :)
hotrod_chevyz
12-01-2006, 11:22 PM
What amp will they be hooked to?
jtvyper456
12-01-2006, 11:29 PM
No idea what amp....Any suggestions? I'm within the $150-200 range, looked at a Boss Blade BL2000...2 Channels...
Amplifier Type: Multi-Channel
RMS Power (http://www.cardomain.com/glossary/glossary.pl?term=rms+power) @ 4 Ohms: 220W x 4
THD (http://www.cardomain.com/glossary/glossary.pl?term=total+harmonic+distortion) at 4-Ohm RMS Power: 0.01%
Bridged RMS Power (http://www.cardomain.com/glossary/glossary.pl?term=bridged+power) @ 4 Ohms: 1000W x 2 (Max)
Speaker Level Inputs (http://www.cardomain.com/glossary/glossary.pl?term=speaker+level+inputs): yes
Preamp Outputs (http://www.cardomain.com/glossary/glossary.pl?term=pre-amp): yes
Built-In Crossovers (http://www.cardomain.com/glossary/glossary.pl?term=active+dividing+network): HP/LP
Bass Boost (http://www.cardomain.com/glossary/glossary.pl?term=bass+boost): 0-18 dB
Frequency Response (http://www.cardomain.com/glossary/glossary.pl?term=frequency+response): n/a
Signal to Noise Ratio (http://www.cardomain.com/glossary/glossary.pl?term=signal-to-noise+ratio): >105 dB
Fuse Rating: n/a
it rates it at 4ohm, from what I understand, I can wire that to 2ohms? I'm new at this...I'll have help from a friend who sells for roadhouse when I go to hook all this up :p
hotrod_chevyz
12-02-2006, 02:34 AM
Fuse Rating: n/ait rates it at 4ohm, from what I understand, I can wire that to 2ohms? I'm new at this...I'll have help from a friend who sells for roadhouse when I go to hook all this up :p
you will be allright with that. Its 2 ohm compatable.
philly rs
12-03-2006, 10:40 AM
damn i had no clue u guys knew about sound....whod a thunk it. everyone seems to rip out the radeo for weight reduction lol
hotrod_chevyz
12-03-2006, 06:16 PM
well, my firebird doesnt have a REAL sound system. It is pretty much stripped out for weight reasons. Its my toy. Im more interested in it for performance reasons than luxury. Just a stock ford stereo with some 6x9's in back and some 3 inch speakers in the dash to drown out the open headers. its for fast, not nice.
I put things like the nicer stereos and other luxury items in my crown victoria. Thats what its for and thats where the dvd player and throbbing sound system lives. I have it for nice not fast.
I learned about electronics when i worked at a shop where we repaired linear amps and other communication equipment. Mostly broadcast equipment like ham radios, cb's ect.
SLPbirdy00
12-03-2006, 08:02 PM
just if its dual 2-ohm coil...do not wire parallel down to 1-Ohm...they make special more expensive amplifiers for that kind of power.
goldz28
12-03-2006, 08:32 PM
I have a Alpine R-10. Does just fine for what I need and hits nice and hard. But I had to save space in the back so I can put my t-tops in the back still.
hotrod_chevyz
12-03-2006, 08:39 PM
you know it bumps when you burp.
my zr600 kicks so hard it could crack pavement.
http://i2.photobucket.com/albums/y18/hotrod_chevyz/8j_2.jpg
Ive had this amp behind my back seat, later hidden in the dash, and now in the CV. Its killed more speakers than i care to think.
philly rs
12-03-2006, 11:44 PM
lol sweet....ill have to take pics of my set up...sum people seen it from my old black camaro, i have the same set up in the f1
hotrod_chevyz
12-03-2006, 11:54 PM
Right now i have no speakers. What i didnt sell i blew up. My box holds two 12's for the firebird. My box isnt even in the car no more but i still have it along with some fried speakers still attached to it. The crown vic can hold a single 15. The last 15 i blew up was pretty cool. The cone down inside the speaker ripped completely off the face of the woofer. It didnt trip out the relay or blow any fuses.
stone_mound_camaro
12-04-2006, 02:04 PM
right now i have two type R, 12s... sealed... with a hifonics tx1005d...got apline 6x9 2-ways in the rear-sides and more alpine 6.5s in the kicks...i got some unknown company's tweeters by my side mirrors
o and jtvyper, stay away from boss....they suck...
98ws6
01-31-2007, 09:36 AM
cerwin vega's are my speaker of choice
instantkevin
02-22-2007, 06:33 PM
(I know this thread is a little old, but it seems there was a little misinformation and I'm curious what happened with the install any way...)
where did you see in those specs that its 2 Ohm stable? I didnt read that.
Ohms are the level of resistance to electrical current. the lower the resistance, the more usable power.
the resistance that your speakers create depends on how you wire the speakers. hence, the chart Stone_mound posted for you. if you bought 2 dual voice coil speakers, the resistance would be .5 Ohms if you just wired them straight up. only really expensive amps can reliably support that and im sure they are well out of your budget range.
even if that amp is 2 Ohm stable, in this case, it wouldnt matter. You would still have a $200 paperweight for an amp, in little time.
I went with a simple setup. A single 10" highpowered Infinity 2 Ohm dual voice coil sub, $250 2 Ohm, monoblock amp (350watts x 1 @ 2 Ohms). Most people think I have 2 12s in the truck, and they dont believe me when I say its one 10.
if you keep the subs, pay an installer/experienced person $5-10 bucks to tell/show you how to wire it without burnin up equipment and wasting money.
hotrod_chevyz
02-23-2007, 11:03 AM
http://www.bossaudio.com/home/catalog/public_html/catalog.php?sNs=1&deptNum=3&catNum=17
scroll down to bl2000 and click on specs.
instantkevin
02-24-2007, 10:07 PM
ok. cool.
Google
Web AF
