2000 T & C AWD Power Window problemjolleyi 11-27-2006, 05:14 PM Recently, my driver side power window has been acting up. It winds down ok but them will not wind back up immediately. After a couple of minutes it will creep up a little, when the switch is pressed, but it will not go all the way up in one shot. Yesterday, on a drive back from San Francisco, eastbound on the 80, it took approx 5 applications of the switch to get the window fully closed, with it rising by varying amounts each time, and always with about 2 minutes between each movement. Any ideas how to fix it??? RIP 11-28-2006, 02:23 PM Window could be bound up on it's tracks. Continued operation could burn up the motor. Could be the motor has gotten weak and needs replacing. Could be the switch. You'll have to remove the interior door panel and troubleshoot it. Barbara41 12-04-2006, 10:43 AM Recently, my driver side power window has been acting up. It winds down ok but them will not wind back up immediately. After a couple of minutes it will creep up a little, when the switch is pressed, but it will not go all the way up in one shot. Yesterday, on a drive back from San Francisco, eastbound on the 80, it took approx 5 applications of the switch to get the window fully closed, with it rising by varying amounts each time, and always with about 2 minutes between each movement. Any ideas how to fix it??? My 2001 Grand Caravan was an electrical nightmare. One of the problems was that the windows would get stuck. I would have to restart the engine. Have the BCM checked. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
