dash board and radio
Google
Web AF
bandolera8468
11-26-2006, 03:50 PM
The only thing that lights up in the dash board is the speed. I can not see my gauges like the oil or how much gas I have. My radio volume goes up and down by itself. What can I do?:frown:
Chris Stewart
11-26-2006, 09:41 PM
What year?
mwtdcb1
04-01-2007, 09:05 AM
I have a 93 Bravada with the same issue - digital dashboard and the only thing that displays is the speed. Did you find a resolution. Thanks
atfdmike
04-02-2007, 06:54 AM
Hi, It sounds like your cluster is about finished. The loss of any readout on this particular cluster means the whole cluster has to be replaced. My odeometer was the first thing to go, and then the whole cluster blinked on and off. You can check the grounds on the instrument panel located on the steering column first, but I have a 1993 S truck that I just had to replace. I found the new one ( used ) on ebay, but they can be hard to find now. They are quite expensive new but I think they are still available. Good luck.
Junky1991
04-02-2007, 11:33 AM
I have seen these on ebay its usually an exchange program you buy one and send in the old one they fix and resell. Worth a try and im sure cheaper than buying a new one.
Google
Web AF
