My 1994 Olds Bravada giving me problems. It's hard to start
Google
Web AF
slamslam
11-24-2006, 02:17 PM
:banghead: I got a 1994 Oldsmobile Bravada and im having trouble starting it. The only way i can get it to start is by spraying starting fluid in it to get it to start. I have replaced the spider injector unit in it 2 times already plus relpaced the fuel tank and the fuel pump. When i go to take off it wants to bog out on me like its choking on fuel. I checked the fuel pressure and it reads 52 lbs. I can only think that my spider injector is going bad again because when i took off the intake their was fuel sitting in around where the injector sits in place at. Could someone tell me what my problem may be or could i be wrong. :banghead: :banghead: :banghead: :banghead:
Chris Stewart
11-24-2006, 06:52 PM
OK, clean or wet with fuel areas on the drivers side is a fuel supply line problem.
Clean or wet with fuel areas on the passenger side is a fuel pressure regulator problem.
Here's more info...
http://www.automotiveforums.com/vbulletin/showthread.php?t=518850
BlazerLT
11-24-2006, 10:47 PM
Replace the nut kit. You have to replace the fuel lines inside the plenum when you replace the injector.
Also, 52psi is too low, it has to be 56-64psi for the truck to start properly.
Google
Web AF
