1995 Camaro Idlejtvyper456 11-23-2006, 02:23 AM My 1995 3.4V6 is idling between 1100 and 1200 RPMs. How do I lower the idle of the car? I don't think it should be idling quite that high....Thanks! goldz28 11-23-2006, 07:25 AM A lot of newer cars you need to have a tuner or something to change the idle through the computer. I am not sure if there is a way to change it mechanically. poormillionaire2 11-23-2006, 06:41 PM Is that the idle at start up or after its warmed up? Cold idle (start up) will always idle high to get fluids going and stuff, but once its warmed up, the idle should knock itself back down. jtvyper456 11-24-2006, 02:16 AM When it gets warm it idles around 900-1000, on a cold crank it's 1200 or so, is this normal? goldz28 11-24-2006, 04:19 AM When it gets warm it idles around 900-1000, on a cold crank it's 1200 or so, is this normal? Thats normal, my z28 when cold idles alil higher than when its warm, when warm idles at 1000rpms philly rs 11-24-2006, 09:14 AM yeah no worries man, most cars do that when cold. mines idles around 1000, then drops to 700-900 somewhere around there vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
