Drivers Door Stuck99_Blazer 11-18-2006, 05:37 PM 1994 Lumina APV. Drivers exterior door handle broke. I replaced it and it worked great. Then it would not open from inside or outside. I looked in with a flashlight and all the linkage is moving but the latch won't disengage. Any help appreciated. LMP 11-19-2006, 03:23 PM ...since it worked previously, there might be a slight position error of one component relative with the other so that it might need just a little extra travel....it this is the case did you try pressing against the door to release tension on the latch while you pull handle at same time...sometimes it works. 99_Blazer 11-21-2006, 07:25 AM Door suddenly started working. Thanks. I think the door was actuallly locked even though the button was up, the key position was sllightly off. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
