3.4 L to a 305 ???
Google
Web AF
camaro king
11-16-2006, 08:36 PM
i have a 3.4L 1994 manual camaro it has a lot of miles and im thinking of putting a 305 in it after i get the money my ? is will the tranny mach up or will i have to get a new tranny to? please respond thanks
666_speed
11-16-2006, 08:58 PM
You will need a new transmission, along with a bunch of other things.
silicon212
11-16-2006, 09:27 PM
Transmission, PCM and wiring harness - along with mounts, radiator (the V6 unit won't adequately cool a 305), and all associated hardware. It's a big job, but can be done. Good luck and God Speed!
camaro king
11-16-2006, 09:29 PM
that sucks man i wonted to be able to just change them out but i jess i will have to replace it with a nother 3.4L V6 man that sucks bad thanks for the help tho
666_speed
11-16-2006, 09:37 PM
About the only things that will transfer over is the drive shaft and rear end (which should be changed to a limited slip one).
Genopsyde
11-20-2006, 07:04 AM
that wouldn't be a good idea for a swap anyway, your 3.4 makes more HP than the TBI 305, and as much HP as the TPI 305.
jveik
11-20-2006, 09:35 AM
yeah i was gonna say, why not just drop a 350 in there
camaro king
11-22-2006, 03:22 PM
i did not think it would fit in the car a 35o is bigger
wrightz28
11-22-2006, 03:45 PM
Internally yes, externally no, they are the same.
camaro king
11-22-2006, 07:28 PM
well i might have to think about that
Google
Web AF
