hate me?Ian Szgatti 11-13-2006, 09:26 PM I have seen the subject come up many times, Imports are better than Domestic. Well, out of sheer painful bordem, I did some research... I put my own 3300 1991 cutlass against same year popular Honda Accord.. TSB information reveals the folling for the 91 Cutlass Ciera 3300 -Technical Service Bulletins Date: 04/15/2004 Component Name: 046300 SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSORNHTSA #: 04152004 SUMMARY: VEHICLES MAY SET ANYONE OR A COMBINATION OF FRONT-WHEEL SPEED SENSOR ANTI-LOCK BRAKE SYSTEM CODES AS INTERMITTENT OR HARD FAILURES. GM VOICEMAIL EXPRESS. *TT Date: 04/15/2004 Component Name: 046300 SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR NHTSA #: 04152004 SUMMARY: VEHICLES MAY SET ANYONE OR A COMBINATION OF FRONT-WHEEL SPEED SENSOR ANTI-LOCK BRAKE SYSTEM CODES AS INTERMITTENT OR HARD FAILURES. GM VOICEMAIL EXPRESS. *TT -- big goddam deal, i can live with that -------------------------------------------------------------------------- Now the TSB information for the ever popular same year Honda Accord: -Technical Service Bulletins Date: 02/14/2002 Component Name: 021000 SUSPENSION:FRONT NHTSA #: 5905 SUMMARY: CUSTOMERS MAY COMPLAIN OF A TWANG NOISE FROM THE FRONT SUSPENSION THAT SOUNDS LIKE A SPRING CONTACT. *SLC Date: 02/14/2002 Component Name: 021000 SUSPENSION:FRONT NHTSA #: 5905 SUMMARY: CUSTOMERS MAY COMPLAIN OF A TWANG NOISE FROM THE FRONT SUSPENSION THAT SOUNDS LIKE A SPRING CONTACT. *SLC Date: 12/08/1998 Component Name: 061100 ENGINE AND ENGINE COOLING:ENGINE:GASOLINE NHTSA #: 98074 SUMMARY: CONCERNS WITH ENGINE HESITATION OR STUMBLE CAN BE FELT UNDER LIGHT ACCELERATION BETWEEN 1,500 AND 2,000 RPM. *YC Date: 10/06/1998 Component Name: 061100 ENGINE AND ENGINE COOLING:ENGINE:GASOLINE NHTSA #: 98074 SUMMARY: SOME VEHICLE MAY EXPERIENCE HESITATION OR STUMBLE. *YC Date: 10/16/2002 Component Name: 061110 ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS NHTSA #: 1002 SUMMARY: TIMING BELT ADJUSTMENT PROCEDURE. HONDA OCTOBER TECH LINE INFORMATION. *TT Date: 11/01/2002 Component Name: 061110 ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS NHTSA #: 110102 SUMMARY: USE '94 ACCORD SERVICE MANUAL TO ADJUST TIMING BELT TENSION. *TT Date: 10/16/2002 Component Name: 061110 ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS NHTSA #: 1002 SUMMARY: TIMING BELT ADJUSTMENT PROCEDURE. HONDA OCTOBER TECH LINE INFORMATION. *TT Date: 11/01/2003 Component Name: 062000 ENGINE AND ENGINE COOLING:COOLING SYSTEM NHTSA #: 11012003 SUMMARY: HEATER BLOWER MOTOR GETS HOT OR BLOWS A FUSE. HONDA. SERVICENEWS. *TT Date: 04/01/2000 Component Name: 063100 ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL NHTSA #: 010400 SUMMARY: INFORMATION ON REPLACING THE O2 SENSOR WHEN EXPERIENCING HESITATION OR DELAY DURING MODERATE ACCELERATION. *TT Date: 08/01/2001 Component Name: 103000 POWER TRAIN:AUTOMATIC TRANSMISSION NHTSA #: 010101 SUMMARY: INFORMATION REGARDING A/T SLIPPAGE. *ET Date: 11/16/2000 Component Name: 103000 POWER TRAIN:AUTOMATIC TRANSMISSION NHTSA #: 161100 SUMMARY: INFORMATION ON VEHICLES EXHBITING A TRANSMISSION THAT SLIPS AFTER DRIVING. *TT Date: 08/01/2001 Component Name: 103000 POWER TRAIN:AUTOMATIC TRANSMISSION NHTSA #: 010101 SUMMARY: INFORMATION REGARDING A/T SLIPPAGE. *ET Date: 08/01/1993 Component Name: 131000 VISIBILITY:WINDSHIELD NHTSA #: 91010 SUMMARY: PARTIALLY OPEN WINDOW RATTLES. *TW Date: 04/01/1993 Component Name: 151100 SEAT BELTS:FRONT:ANCHORAGE NHTSA #: A930029 SUMMARY: PRODUCT IMPROVEMENT CAMPAIGN: REAR SEAT BELT RETRACTOR SENSOR. *TW Date: 02/01/1993 Component Name: 162300 STRUCTURE:BODYhttp://www.oldspower.com/vb/images/smilies/biggrin.gifOOR NHTSA #: 93005 SUMMARY: DOORS OR WINDOWS HARD TO OPEN. *TW Date: 01/01/1995 Component Name: 190000 TIRES NHTSA #: 93011R SUMMARY: FRONT AND REAR TIRE WEAR. *TW Date: 09/24/2002 Component Name: 200000 WHEELS NHTSA #: 02057 SUMMARY: SOME VEHICLES MAY EXHIBIT GROWLING OR WHINING FROM ONE OR BOTH OF THE REAR WHEELS WHEN DRIVING. *TT Date: 03/31/1997 Component Name: 204000 WHEELS:CAP/COVER/HUB NHTSA #: 97018 SUMMARY: REAR WHEEL BEARING NOISE. *JD Date: 10/01/1998 Component Name: 330000 INTERIOR LIGHTING NHTSA #: 011098 SUMMARY: INFORMATION ON DIAGNOSING THE CEILING LIGHTS. *TT Date: 05/01/2004 Component Name: 350000 EQUIPMENT NHTSA #: 05012004 SUMMARY: AUDIO UNIT AND NAVIGATION SYSTEM ANTI-THEFT CODES AVAILABLE ON INTERACTIVE NETWORK. *NM Date: 05/01/2004 Component Name: 350000 EQUIPMENT NHTSA #: 05012004 SUMMARY: AUDIO UNIT AND NAVIGATION SYSTEM ANTI-THEFT CODES AVAILABLE ON INTERACTIVE NETWORK. *NM Date: 04/16/2004 Component Name: 353100 EQUIPMENT:ELECTRICAL:ANTI-THEFT DEVICES NHTSA #: 404 SUMMARY: AUDIO, ANTI-THEFT CODES. HONDA. TECH LINE SUMMARY. *TT Date: 08/01/2001 Component Name: 980000 OTHER NHTSA #: 010101 SUMMARY: INFORMATION REGARDING A/T SLIPPAGE. *ET Sooooo, thats pretty much the kinda proof I need vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
