97 Eclipse RPM Gauge
VictorPerez
11-13-2006, 01:29 PM
Ok heres the deal I want to hook up a RPM gauge but i cant seem to find out which cable is the one you hook it up to so the RPM could work i got the lights, the ground, and the power but all i need is the Rev cable if some one could send me a picture to were its located id appreciated
gthompson97
11-13-2006, 01:38 PM
Why would you want to hook up another RPM gauge?
Killa
11-13-2006, 02:03 PM
Are you try to hook up the tac ?
defiancy
11-13-2006, 02:11 PM
I'm assuming he means an aftermarket guage with a shift light and crap.
david-b
11-13-2006, 02:16 PM
There's a wire located the ECU. I don't know if it's turbo or non so I can't give an exact location. But there is a wire where you tap in and it'll work. Some one will have a diagram somewhere. If no one has by the time I get home I'll post it then. Is it turbo or non?
Killa
11-13-2006, 02:33 PM
sound like he have turbo.
l_eclipse_l
11-13-2006, 02:37 PM
How can you tell from reading his post?
VictorPerez
11-13-2006, 02:44 PM
No its a Non Turbo this car isnt mine its my brothers he whats to add stuff like that
david-b
11-13-2006, 03:04 PM
On the non turbo, the ECU is in the enigne bay on the driver side right behind the fuse box near the battery.
-Disconnect the battery
-Take off the little clip that covers all the wires facing towards the engine.
-I believe there is a 8mm bolt in the middle you have to take off also. This will expose all the wires going to the ECU.
-In that whole group of wires, look for a solid white wire. It's located on the lower 73 pin. It's the only SOLID white wire in that whole group.
-Strip a piece of the wire and hook the tach up to it there. Make sure you wrap the wire with heat shrink and even tape it up then too.
-Reconnect the cover to the ECU and rebolt it on.
-Reconnect the battery
Write up by ME!!
Write up by ME!!
VictorPerez
11-14-2006, 12:51 AM
Thanks Alot David-b I Found It And Every Thing Is Working Like It Shound Once Again Thanks For The Help
david-b
11-14-2006, 10:27 AM
Anytime
