No Heat in rear of 2004
Google
Web AF
stucake
11-12-2006, 08:16 PM
Hi Guys I have a 2004 chevy tahoe z71 with 45k and the rear heat has recently stopped working. Is there sensor or something gone bad? If where is it how do I fix it. The dash heat works like new. The rear always blows cold.
Thanks in advance
greengumby
02-16-2007, 07:45 PM
hey did you ever get this fixed ?
I'm starting to have the same problem now .. :disappoin
lweford
02-17-2007, 04:20 PM
You probably have a blend door motor bad. The one that switches from hot to cold. It is a easy thing to figure out. Just pop off the passenger side interior molding behind the rear fender. You will find a black air box with two blend motors attached to the outside. One is for upper and lower air flow and the other is for hot or cold air. Have someone turn the hot and cold control while you look at the round white shaft that goes through the motor. You should be able to see it turning slowly when they work the control knob. If it doesn;t turn then you might swap motors to be sure. Real simple, three screws and they slide off the blend door shaft.
greengumby
02-20-2007, 06:18 PM
lweford,
Thanks alot there buddy! ...i found out that i had some type of debris in the motor shaft or something ended up replacing the motor ... now the back end has that nice warm air pumpin through ...
Google
Web AF
