Clicking noisettNATION 11-10-2006, 06:47 AM Got a 96 Villiger that always has a loud clicking noise everytime the heater is on. Its coming from the engine but cant pin point it. Any suggestions or answers? thanks IH8SPM 11-15-2006, 11:38 AM Try the thermostat. Or the IAC valve. ttNATION 11-15-2006, 12:54 PM Try the thermostat. Or the IAC valve. Hey thanks I will check into it by the way what is the IAC valve and where is it located? Thanks again IH8SPM 11-16-2006, 06:10 AM Center of the engine rear near the fire wall ontop of the intake manifold. ttNATION 11-20-2006, 11:00 PM Center of the engine rear near the fire wall ontop of the intake manifold. Hey thanks for the info. I got more details about the clicking noise. It only clicks when the heater is on the defroster setting. And when I pop the hood it starts when the fan is activated. Does this help alittle more for ya. Thanks IH8SPM 11-27-2006, 06:18 AM It sounds like the relay is clicking if its in the car and if its from the engine you may a fan blade hitting something. You may need to turn off the van a few times with someone else so you can check for the noise to see if it slows down when its off. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
