Couple question please answer !!
Killa
11-08-2006, 10:02 PM
I just take my bov recurlate pipe, and found oil in there, then I take air intake pipe and found some oil in there too, and even some in turbo ?? WTF ??
1: I can blow thru my pcv valve both way, you think that can cause oil get into upic and into bov then turbo ?
2: when I take my air intake pipe, I saw 2 bolt that hold the shifter to the tranny, they kinda loose, then I hold shifter bushing, then I move it left and right, it kinda loose, should I tight those 2 bolt or it loose like that is normal ?
Thor06
11-08-2006, 10:35 PM
The oil is probably from the valve cover breather hose going from the valve cover to the intake.
Killa
11-08-2006, 10:48 PM
I saw alot oil come out from the valve cover into breather ( I put a fulse filter there ). Why oil coming out from the valve cover like that ?
blk_srt
11-08-2006, 11:01 PM
change your pcv valve. If I'm thinking about the same thing you are those bolts arent bolts, they are pins with a cotter pin at the end and they are supposed to be that loose
Killa
11-08-2006, 11:05 PM
There is a braket with 2 bolt that bolt into the tranny, that braket hold 2 shifter thing together.
so the alot oil come out to breather becaue bad pvc ?
blk_srt
11-08-2006, 11:19 PM
yes.
Your talking about the shifter cables right? Are you talking about the bolt that goes through the cables that holds them of the shifting base?
Killa
11-08-2006, 11:29 PM
gthompson97
11-08-2006, 11:32 PM
Yes, those bolts are suposed to be tight, I'd tighten them before they fall out.
Killa
11-08-2006, 11:44 PM
Done
Done
Killa
11-08-2006, 11:46 PM
when doing boost leak test, do you have to block the hose that from the valve cover to the intake ?
blk_srt
11-09-2006, 07:19 AM
it would be a good idea. Also if you have a bleeder type MBC you need to block that off.
